remote control, karr alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118126
Printed Date: May 19, 2024 at 5:06 PM
Topic: remote control, karr alarm
Posted By: el ranchero
Subject: remote control, karr alarm
Date Posted: November 30, 2009 at 2:48 PM
i looking for a remote replacemt for a karr alarm, they want $50 for one, any body know of a replacemnt this one works on the 302 mhz and is code hopping. thanks
------------- rocker
Posted By: Chris Luongo
Date Posted: November 30, 2009 at 10:34 PM
I'm pretty sure those were just rebadged Audiovox alarms.
Any pictures of either the remote or the brain?
It's possible that certain Audiovox remotes would work. There are many used ones on eBay for not too much money.
Posted By: mikvot
Date Posted: December 01, 2009 at 8:23 AM
There are only two different transmitters used. One is for the older stuff , which as Chris mentioned, is rebadged Audiovox. And a different transmitter for the newer HP product. I have multiple transmitters for both systems laying around. The older transmitter has 3 buttons, and the newer one has 4 buttons. If you want a couple, let me know.
Posted By: mike2t
Date Posted: December 01, 2009 at 10:06 AM
I ran into the same problem with an older alarm I had, but by the time I replaced the remote it was just about the price of a new one. So that's what I did which maybe just as cost effective than searching for a replacement. Heck, I found a smoking deal on an alarm (APS-997N) for just a few dollars more than then 2way remote i was using. Good Luck in your remote hunting. -------------
Mike T
Date Posted: December 01, 2009 at 5:56 PM
thank you all or your help.
