wiring information honda pilot 2003
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118664
Printed Date: June 09, 2024 at 3:20 PM
Topic: wiring information honda pilot 2003
Posted By: eugen
Subject: wiring information honda pilot 2003
Date Posted: December 19, 2009 at 3:32 PM
Hi i would like to install a remote starter in my honda pilot 2003
is their somebody who can give me the wiring information for that car
THANKS
------------- Schmidt
Posted By: i am an idiot
Date Posted: December 19, 2009 at 7:23 PM
| Battery | | WHITE | | (+) | | IGNITION SWITCH HARNESS | | | | Ignition 1 | | BLACK / YELLOW | | (+) | | IGNITION SWITCH HARNESS | | | | Accessory 1 | | YELLOW | | (+) | | IGNITION SWITCH HARNESS | | | | Accessory 2 | | WHITE/ BLACK | | (+) | | IGNITION SWITCH HARNESS | | | | Starter 1 | | BLACK/ WHITE | | (+) | | IGNITION SWITCH HARNESS | | | | Anti-Theft Type | | UNIVERSAL IMMOBILIZER | | | | Anti-Theft Descript | | THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER | | | | Key Sense | | BLUE/BLACK | | (-) | | AT COLUMN SEVEN WIRE HARNESS TOP OF COLUMN | | | | Tachometer | | BLUE/SILVER DOTS OR (BLUE) | | (AC) | | @ 2 PIN BLK CONN. TAPED NEAR THE BATTERY | | | | Speed Sense | | BLUE/WHITE | | (AC) | | CRUISE CONTROL HARNESS BEHIND PASS. SIDE HEADLIGHT | | | | Parking Lights | | RED / BACK | | (+) | | DRIVERS KICK PANEL | | | | Low Crr. Pk Lights | | RED / YELLOW | | (-) | | HEADLIGHT SWITCH | | | | Brake Lights | | WHITE/ BLACK | | (+) | | @ SWITCH ABOVE BRAKE PEDAL | | | | Reverse Lights | | GREEN/ BLACK | | (+) | | DRIVERS KICK PANEL | | | | Horn | | LIGHT GREEN/ BLUE | | (-) | | AT STEERING COLUMN HARNESS |
