95 cherokee ungo install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11871
Printed Date: May 14, 2024 at 8:24 PM
Topic: 95 cherokee ungo install
Posted By: rkelley7
Subject: 95 cherokee ungo install
Date Posted: April 06, 2003 at 7:22 PM
I'm installing a ungo ms2005 and I am having trouble with the alarm re-arming itself when I try to disarm it. I have installed most of the system so far, but this has me at a stand still.
------------- Rob
Posted By: blazo
Date Posted: April 06, 2003 at 7:28 PM
u have to use the programing to turn passive arming off.
read u'r manual, it'll be in there somewhere.
Posted By: rkelley7
Date Posted: April 06, 2003 at 7:41 PM
Is there a wire for the factory alarm that I have to hook into for the ungo to disarm it.
------------- Rob
Posted By: Velocity Motors
Date Posted: April 06, 2003 at 9:53 PM
FCTRY ALRM DISARM|GREEN/ orange |- |drivers kick panel
------------- Jeff
Posted By: rkelley7
Date Posted: April 07, 2003 at 6:15 AM
Thanks guys for the info. I went to the vehicle info file and it lists the factory disarm as purple / YELLOW, and i didn't see any wires with that color so I was stumped.
------------- Rob
Posted By: rkelley7
Date Posted: April 07, 2003 at 2:21 PM
I looked for the GREEN/ orange wire but had no luck. There are a solid green and an ORANGE / white wires in the harness going to the drivers door in the lower kick panel. Will the wire I need be in the harness going to the door? Please Help !!!
------------- Rob
Posted By: rkelley7
Date Posted: April 07, 2003 at 3:23 PM
This is the first ungo I have installed and I have a few questions. If anyone has installed this model or has knowledge of it can you help me out.
------------- Rob
