2009 vw rabbit bypass?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118736
Printed Date: May 16, 2024 at 3:13 AM
Topic: 2009 vw rabbit bypass?
Posted By: shadowinfector
Subject: 2009 vw rabbit bypass?
Date Posted: December 22, 2009 at 11:17 AM
anyone know which bypass kit i can use for the immobilizer? i am not sure if i can use 556uw or 556u, I am also planning on using the cansl2... any info in this vehicle, i have a potential customer bringing the car to me in the next couple of days. Any help would be greatly appreciated. Thank You
Posted By: zerepdivad
Date Posted: December 22, 2009 at 1:41 PM
556u is where it's at on that vehicle for immobilizer.
------------- A DMM is a beautiful thing.
Date Posted: December 22, 2009 at 6:36 PM
thanks....has anyone worked on this vehicle? is the wiring diagram the same as the 2007??? thanks
Posted By: 05gt
Date Posted: December 22, 2009 at 11:20 PM
you need to use the 556U from DEI for the immobilizer bypass, and you will need to use a piece from Idatalink if you want to avoid some headaches idatalinks volkswagen platforms are almost bulletproof and are most of the time are 2 wire hookup, well in your case it will be 3 wires
Posted By: Velocity Motors
Date Posted: December 23, 2009 at 6:42 AM
Same as the 07's
------------- Jeff
Date Posted: December 23, 2009 at 3:43 PM
thanks, I could also use the can-sl2 from fortin correct?
Date Posted: December 23, 2009 at 3:44 PM
2009 VW Rabbit
Posted By: tedmond
Date Posted: December 23, 2009 at 4:52 PM
go to www.ifar.ca, select your car and you will find out. sorry shadow infector, but not all info can be spoon fed to ya.
Date Posted: December 24, 2009 at 6:03 PM
hahaha, damn you dont have to be harsh i just wanted to see if any other installer has used done this car with that module and if they had any problems
Posted By: nade2175
Date Posted: January 17, 2010 at 11:41 PM
go to viper.com click interface module and then type your car year and model it tells you what module you need, hope this will help...
------------- viper arm
Posted By: howie ll
Date Posted: January 18, 2010 at 1:52 AM
And when you install the 556U set it up as the European instructions, DON'T use the antenna loop.
