viper 5701 2 way remote
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=119536
Printed Date: April 03, 2026 at 5:06 AM
Topic: viper 5701 2 way remote
Posted By: justingod
Subject: viper 5701 2 way remote
Date Posted: January 21, 2010 at 8:04 PM
Just installed a 5701 in a 1996 nissan altima. The 1-Way works flawlessly.  I am having error lights on the 2-way remote.
I verified all zones secure, and waited to post until today after I got new batteries for the remote.
I have deleted both remotes and reprogrammed them.
I disconnected the battery for a over 30 minutes.  I have everything applicable hooked up except the tach wire which really doesn't have any bearing on this.
What happens is that the 2-way function RED LED goes off and the top AMBER LED flashes.  No abnormailties from siren or antenna LED.  Funny thing is that sometimes the 2-way beeps and sometimes it doesn't!
Is there any way to clear the remote memory?  I tried shorting the battery contacts, but that didn't work.
How do you reset the brain?
Thanks in advance!!!
I've done mercedes (with those awesome vacuum locks!), volvo, bmw, etc.  I thought Nissan was gonna be easy! This freaking little car required two isolation relays and then another relay for a trunk solenoid I decided to put in (this was DEI's fault though, solenoid should have a trigger).  Time consuming, but easy enough, however, what made this install hellacious was disconnecting an unused 1996 keyless/alarm module.  The single owner I bought from said it hadn't worked since the late 90's!.  It had obviously been wired by a complete idiot. Well, after fixing all the connections and making sure the old alarm connections were properly terminated I'm quite disappointed with the outcome!
Date Posted: January 22, 2010 at 6:31 PM
I don’t think it’s the low battery warning, these errors are different than what the manual states.  I’ve had this installed since last weekend, so I’ve been able to fine tune and go over any of the obvious mistakes.
I really appreciate a quick response!  I still have a navigation head unit and 2 pairs of component speakers to install and would love to have everything done by the end of this weekend.
Here’s what I’ve done so far for troubleshooting:
1.      I’ve deleted both remotes and reprogrammed them to the brain.
2.      I’ve disconnected the car battery for over an hour.
3.      I’ve verified inputs on every zone.
4.      Took batteries out and put back in remotes.
Is there a way to reset the memory on the remotes themselves?  I tried shorting the positive & negative battery leads, but that didn’t work.
Here is the list of everything I hooked up, I put a Y next to the wires I used and left blank the wires I didn’t hook up.  I know how to wire the vehicle, it’s the control module I’m worried might need something put to ground, etc.  BTW the car is a 1996 Nissan Altima GXE with no factory alarm.  The door pin, trunk pin, hood pin, brake shutdown all work fine.  The lock, unlock, sensor/siren and remote start all work fine.  I read this is a common issue and some people have put a 10k resistor on the antenna wire and some people pulled the fuse from the brain.  If either of these work, please let me know and let me know how to pull the brain’s fuse if that will work.
Primary harness (H1), 12-pin connector
Y         H1/1 RED / WHITE (-) 200mA TRUNK RELEASE OUTPUT
Y         H1/2 RED (+)12v CONSTANT INPUT
Y         H1/3 BROWN (+) SIREN OUTPUT
            H1/4 WHITE/ BROWN  LIGHT FLASH ISOLATION WIRE
Y         H1/5 BLACK (-) CHASSIS GROUND
            H1/6 VIOLET (+) DOOR TRIGGER INPUT
Y         H1/7 BLUE (-) TRUNK PIN/ INSTANT TRIGGER INPUT
Y         H1/8 GREEN (-) DOOR TRIGGER INPUT
            H1/9 BLACK/ WHITE (-) 200mA DOME LIGHT OUTPUT
        H1/10 WHITE/ BLUE (-) REMOTE START/TURBO TIMER
Y         H1/11 WHITE PARKING LIGHT OUTPUT
        H1/12 ORANGE (-) 500mA GROUND WHEN ARMED OUTPUT
Auxiliary harness (H2), 8-pin connector (NO FACTORY ALARM)
        H2/1 LIGHT GREEN/ BLACK (-) 200mA FACTORY ALARM DISARM
        H2/2 LIGHT GREEN / WHITE  (-) 200mA FACTORY ALARM ARM
        H2/3 WHITE/ VIOLET (-) 200mA AUX 1 OUTPUT
        H2/4 VIOLET/BLACK (-) 200mA AUX 2 OUTPUT
        H2/5 WHITE/ BLACK (-) 200mA AUX 3 OUTPUT
        H2/6 LIGHT BLUE (-) 200mA 2ND UNLOCK OUTPUT
        H2/7 GRAY/BLACK (-) DIESEL WAIT TO START INPUT
Y         H2/8 BROWN / BLACK (-) 200mA HORN HONK OUTPUT
Door lock harness, 3-pin connector
Y         1 BLUE (+) LOCK (-) UNLOCK OUTPUT
        2 EMPTY NOT USED
Y         3 GREEN (-) LOCK (+) UNLOCK OUTPUT
Heavy gauge remote start, (H3) 10-pin connector
Y         1 PINK (+) IGNITION 1 INPUT/OUTPUT
        2 RED / WHITE (30A) FUSED IGNITION 2 / FLEX RELAY INPUT 87
Y         3 ORANGE ACCESSORY OUTPUT
Y         4 VIOLET (+) STARTER OUTPUT (CAR SIDE STARTER KILL WIRE)
Y         5 GREEN (+) STARTER INPUT (KEY SIDE STARTER KILL WIRE)
Y         6 RED (+) FUSED (30A) IGNITION 1 INPUT
        7 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT
        8 PINK/BLACK FLEX RELAY INPUT 87A key side (if required) of FLEX RELAY
Y         9 RED / BLACK FUSED (30A) ACCESSORY/STARTER INPUT
        10 N/C N/C
Remote start input, 5-pin connector
        1 BLACK/ WHITE (-) NEUTRAL SAFETY SWITCH INPUT
        2 VIOLET/WHITE TACHOMETER INPUT WIRE
Y         3 BROWN (+) BRAKE SHUTDOWN WIRE
Y         4 GRAY N/O or N/C (-) HOOD PIN SWITCH INPUT, ZONE 6
        5 BLUE/WHITE (-) 200 mA 2ND STATUS/REAR DEFOGGER
Remote start auxiliary output, 5-pin  (DIDN’T HOOK UP)
        1 PINK/WHITE (-) 200mA FLEX RELAY CONTROL OUTPUT
        2 ORANGE (-) 200mA ACCESSORY OUTPUT
        3 VIOLET (-) 200mA STARTER OUTPUT
        4 PINK (-) 200mA IGNITION 1 OUTPUT
        5 BLUE (-) 200mA STATUS OUTPUT
<"Times New Roman">
