python 460hp, two alarms on one wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=119560
Printed Date: April 03, 2026 at 6:39 AM
Topic: python 460hp, two alarms on one wire
Posted By: sparky23
Subject: python 460hp, two alarms on one wire
Date Posted: January 23, 2010 at 11:30 AM
I have the DEI Python 460HP and am wondering if it is ok to hook two sirens up to the same H1/10, BROWN, wire siren output?
Also wondering since this alarm has only one sensor port how can I add more sensors later on if I want to?
Posted By: chev104275
Date Posted: January 23, 2010 at 1:16 PM
for the sirens i would use a relay
you can tie the blues and greens together on the sensors use diodes    just remember the more sensors   the more chances of alarm triggers and a hard time finding out what sensor is causing the trigger
