remote start, 95 integra
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=119609
Printed Date: April 06, 2026 at 11:46 PM
Topic: remote start, 95 integra
Posted By: jdmtegg
Subject: remote start, 95 integra
Date Posted: January 24, 2010 at 10:03 PM
Hey Guys,
Im installing a viper 5101 and i was wondering if anyone could help me out. I know where all the wires are in the car but im not quiet sure which wires from the harness go to which ones in the car
1-Pink = Ignition 1 Input/Output
2-RED / White = (+) (30A) Fused Ignition 2 / Flex Relay Input #87
3-Orange = Accessory Output
4-Violet = Starter Output
5-Red = (+) (30A) Fused Ignition 1 Relay Input
6-Pink/White = (+) Ignition 2 Flex Relay Output
7-Pink/Black = 87a Of Ignition 2 Flex Relay
8-Red Black = (+) (30A) Fused Accessory/Starter Relay
H1/1- RED / WHITE (-) 200mA AUX/TRUNK OUTPUT
H1/2- RED (+) 12DC CONSTANT INPUT
H1/3- BROWN (+) SIREN OUTPUT
H1/4- WHITE/ BROWN PARKING LIGHT ISOLATION WIRE pin 87a on onboard rly H1/5- BLACK (-) GROUND
H1/6- VIOLET (+) DOOR TRIGGER INPUT
H1/7- BLUE (-) TRUNK PIN/ INSTANT TRIGGER INPUT (N/C N/O)
H1/8- GREEN (-) DOOR TRIGGER INPUT (N/C N/O)
H1/9- BLACK/ WHITE (-) 200mA DOME LIGHT SUPERVISION OUTPUT
H1/10- WHITE/ BLUE (-) REMOTE START/TURBO TIMER ACTIVATION INPUT
H1/11- WHITE PARKING LIGHT OUTPUT
H1/12- ORANGE (-) 500mA GROUND WHEN ARMED OUTPUT
H2/1- LHT GRN/BLK (-) 200mA OEM ALARM DISARM OUTPUT
H2/2- ORG/BLK (-) 200mA AUX 4 OUTPUT
H2/3- GRN/WHT (-) 200mA OEM ALARM ARM OUTPUT
H2/4- VIOL/BLK (-) 200mA AUX 2 OUTPUT
H2/5- WHT/BLK (-) 200mA AUX 3 OUTPUT
H2/6- WHT/VIOL (-) 200mA AUX 1 OUTPUT
H2/7- GRY/BLK (-) 200mA DIESEL WAIT TO START (dont think we need this one LOL)
H2/8- BRW/BLK (-) 200mA HORN HONK OUTPUT
H2/9- VIOL/WHT TACHOMETER INPUT
H2/10- DRK BLU (-) 200mA STATUS OUTPUT
H2/11- PINK/WHT (-) 200mA FLEX RELAY CONTROL OUTPUT
H2/12- ORG (-) 200mA ACC OUTPUT
H2/13- PRPL (-) 200mA STARTER OUTPUT
H2/14- PINK (-) 200mA IGNITION 1 OUTPUT
H2/15- GRY (-) 200mA HOOD PIN INPUT (N/C N/O)
H2/16- BLU/WHT (-) 200mA 2ND STATUS/REAR DEFFOGER OUTPUT
H2/17- BRW (+) BRAKE SHUTDOWN INPUT
H2/18- BLK/WHT (-) NEUTRAL SAFETY INPUT
like where does the remote start input go to? Do i need all these wires? Like i said i know where the location is if someone could just write which color goes to which wire in teh car for me that would be great
So my question is what colors go together from the harness to the car?
MY Car is a 95 Acura INtegra
Posted By: t&t tech
Date Posted: January 25, 2010 at 4:09 PM
1995 Acura Integra Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+ White  Ignition Switch Harness
Starter BLACK/ White  Ignition Switch Harness
Ignition BLACK / YELLOW  Ignition Switch Harness
Ignition 2 WHITE/ Black  Ignition Switch Harness
Accessory Yellow  Ignition Switch Harness
Tach Blue  Distributor
Neutral Safety Wire GREEN / WHITE  Gear Select Switch
Brake Switch GREEN / WHITE  Brake Switch
Trunk Pin Green (-)  Driver's Kick Panel or Factory Alarm
Parking Lights RED / Green  Green Connector above Fuse Panel
Head Lamp RED / White  Steering Column low beam
Hood Pin n/a
Factory Disarm With Keyless Entry
Door Trigger GREEN/ Red (-)  Driver's Kick Panel or Factory Alarm
Door Lock BLACK/ White (-)  Driver's Kick Panel
Door Unlock BLACK/ Red (-)  Gray Connector behind Cruise Control Module
Horn Wire Blue/Green (-)  Steering Column
Windows Up LF=RED / Yellow, RF=Blue/Red, LR=GREEN/ YELLOW, RR=Yellow
Windows Down LF=RED / Blue, RF=Blue/White, LR=Green, RR=YELLOW /GREEN
Posted By: t&t tech
Date Posted: January 25, 2010 at 4:18 PM
ALARM                                   CAR
PINK                                 BLACK / YELLOW
RED / WHITE                        WHITE
ORANGE                             YELLOW
VIOLET                          BLACK/ WHITE
RED                                       WHITE
PINK/WHITE                   WHITE/ BLACK
PINK/BLACK                          UNUSED
RED / BLACK                           WHITE
On the H1 harness you will only need a few wires
Red - Constant twelve
black-Ground
Browm- Siren
White- RED / green (car)
Green- GREEN/ red
No need for the harness under the h1 harness!
On the last harness the only wires you need are the
grey-  hood switch
brown- GREEN / WHITE (car)
BLACK/ white- ground.
Posted By: jdmtegg
Date Posted: January 26, 2010 at 3:04 PM
so everything is connected like this and it turns the car on like power wise all the blowers and electronics turn on but the engine does not start
Posted By: Mike M2
Date Posted: January 26, 2010 at 3:56 PM
It may be too old, but does it have an immobilizer?
Did you power the RED / black?
Mike M2
Tech Manager
CS Dealer Services
Posted By: howie ll
Date Posted: January 26, 2010 at 4:04 PM
Clutch switch if manual?
Posted By: t&t tech
Date Posted: January 26, 2010 at 4:30 PM
What happens?
Also, did you use a meter to test or did you just connect as per the diagram?
Posted By: jdmtegg
Date Posted: January 27, 2010 at 3:02 PM
its not the clutch i ruled that one out because i sat in teh car and held in the clutch and it didnt work Teh red and black have power. and no i didnt use that meter to test but im positive the wires are correct could it be the programing of the remote
Posted By: t&t tech
Date Posted: January 27, 2010 at 3:42 PM
How are you positive if you didn't test? Do you have a meter?
Posted By: Thack79
Date Posted: January 27, 2010 at 4:03 PM
does it even attempt to start???
