2006 Acura MDX Factory Alarm Problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=119740
Printed Date: May 21, 2024 at 1:27 PM
Topic: 2006 Acura MDX Factory Alarm Problems
Posted By: phat-focus
Subject: 2006 Acura MDX Factory Alarm Problems
Date Posted: January 29, 2010 at 2:11 PM
Okay heres the scoop... Installed a code alarm 5050 (remote start/keyless only!) with dei pk34h. Everything is fine with that, im just having tons of issues with the factory security. The customer says the horn will sometimes go off when he starts it, or after he unlocks and opens the door. I did use the disarm wire inside the driver door. BLACK/ Red. The locks, i got at the passenger fuse panel. This last time the guy came back i just grounded the FAD wire in the door but it still is acting up. Today he just told me that the car has LoJack installed on it. He doesnt pay for the service anymore, but could this be causing false triggers or causing the vehicle to act up? Any help is appreciated.
------------- Driversphere.com
Plainfield/Joliet Illinois.
Flatline till I Flatline
Posted By: kgerry
Date Posted: January 29, 2010 at 5:01 PM
i'm pretty sure i always grabbed my disarm in the passenger kick on those vehicles.... you may want to double check your wiring info... i've never had any issues....
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: lectricguy
Date Posted: January 29, 2010 at 7:48 PM
The arm and disarm wires are available in the passenger's kick panel, and they also control the doorlocks. The wires are located above the passenger side fusebox, in a horizontal plug, with the wires coming in from the passenger door.
To find the the two correct wires, one will test as a ground when you turn the key in the door key cylinder to lock the door, and the other will test as a ground when you turn the key in the door key cylinder to unlock the door. Connect both your CA5050 lock and factory alarm arm/pulse after shutdown wires to the wire that tests as a ground in the lock position; connect your CA5050 unlock and factory alarm disarm/pulse before start wires to the wire that tests as a ground in the unlock position. Now your remote start should both arm and lock the doors when the keyfob lock button is pressed; the remote start should both disarm and unlock all doors when the keyfob unlock button is pressed.
------------- Lectric Guy
Posted By: gabedemelo
Date Posted: January 29, 2010 at 10:09 PM
sounds like disarm wire has bad connect,.. pinched or bad butt if you used, hopefully you didnt use t-tap
------------- GreenGables
Posted By: tedmond
Date Posted: January 29, 2010 at 10:52 PM
they are in the PKP and in the door as well. if you do what lectricguy said, make sure you diode isolate the wires. band towards alarm.
------------- Ted
Compustar Expert
Posted By: nver2loud
Date Posted: February 06, 2010 at 6:01 PM
I have had this same problem this weekend. I can confirm that the disarm is actually blue w/silver dots at the driver window switch controls. You can test like normal with the key in the drivers door, BUT it is not the wire that will stay grounded after you release the key, that is what I had my disarm connected to, and the factory alarm kept going off.
Posted By: muaiad97
Date Posted: February 09, 2010 at 12:07 AM
u dont need any extra wire just programe it to standard lock i mean program it to unlock befor start tne relock after start it shold work with no any problems i did so many acura with no problem
Date Posted: February 23, 2010 at 4:24 PM
Thanks guys, sorry i didnt reply sooner, thought i fixed the problem. The vehicle is coming in this week so i will be grabbing the wires in pass. kick instead of drivers door. Man i love this forum. ------------- Driversphere.com
