viper 5301 remote start wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=119821
Printed Date: May 29, 2024 at 3:33 AM
Topic: viper 5301 remote start wiring
Posted By: daddy249
Subject: viper 5301 remote start wiring
Date Posted: February 01, 2010 at 11:20 PM
Can anyone help me out with a wiring diagram for a Viper 5301 in a 2002 Chevrolet Silverado?
Posted By: gvallen
Date Posted: February 07, 2010 at 11:05 PM
2002 - 2004 CHEVY SILVERADO WIRING INFO
Constant 12v = Red @ Steering column
Ignition 1 = Pink (Necessary) @ Steering column
Ignition 2 = White (Necessary) @ Steering column
Accessory = Orange (Necessary for ac/heat) @ Steering column
Accessory 2 = Brown (Usually Optional) @ Steering column
Starter = Yellow @ Steering column
Horn = Black or BLACK / YELLOW (-) @ Steering column
Brake = White or light blue @ brake switch
Park Lights
2002 = Brown (+) @ BCM
2003 - 2004 = Gray/Black (-) @ BCM
Locks
2002 = Light Blue (+) = Lock @ BCM
2002 = White (+) = UnLock @ BCM
2003 - 2004 = Use a databus module
Passlock 2
2002 - 2004 = Use a databus bypass module
Park Lights
Locks
Passlock 2
Park Lights
Locks
Passlock 2
WIRING DIAGRAM FOR 5301
  1. RED / white   (-) 200ma trunk release output
  2. red  (+)  12vdc constant input
  3. brown (-) horn honk ouput
  4. WHITE/ brown light flash isolation wire
  5. black (-) ground
  6. violet (+) door triger input
  7. blue factory horn input
  8. green (-) door triger input  n/c  or n/o
  9.  BLACK/ white (-) dome light output
  10. WHITE/ blue(-) remote start/ tutbo timer activation input
  11. white parking light output
  12. orange(-) ground when armed output
H2
  1. light GREEN/ black factory alarm disarm output
  2. ORANGE / black aux 4 output
  3. GREEN / WHITE factory alarm arm output
  4. violet/black aux 2 ouput
  5. WHITE/ black aux 3 output
  6. WHITE/ violet aux 1 output
  7. gray/black diesal wait to start
  8. empty
  9. violet/white tack input
  10. dark/blue status output
  11. pink/white flex relay control output
  12. orange axxesory output
  13. purple starter output
  14. pink ignition  1 output
  15. grey hood pin
  16. blue/white 2nd statis / rear defrogger output
  17. brown (+) brake shutdown input
  18. BLACK/ white  neutral safty input
H3
  1. pink ignition 1 input/output
  2. RED / white fused (30a) ignition 2 flex relay input 87
  3. orange accesory output
  4. violet starter output
  5. red fused (30a) igniton 1 input
  6. pink/white ignition 2 / flex relay output
  7. pink/black flex relay input 87a key side  if required
  8. RED / black fused (30a) accessory/ starter input
Posted By: Johnnynguyen20
Date Posted: February 12, 2010 at 12:06 PM
i have added the Installation manual and Owner Manual on the download section. go to download and search for Viper 5301
Johnnynguyen
Posted By: daddy249
Date Posted: February 12, 2010 at 3:10 PM
Awesome thanks guys!
