hornet maxx1 750t alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=119936
Printed Date: May 20, 2024 at 10:17 PM
Topic: hornet maxx1 750t alarm
Posted By: actionuk
Subject: hornet maxx1 750t alarm
Date Posted: February 06, 2010 at 5:36 PM
i am in need of the wiring diagram/setup for a hornet maxx1 750t car alarm if anyone can help please let me know
Posted By: calijtee1
Date Posted: February 09, 2010 at 1:54 AM
can you tell me the colors of the wires on the alarm.. ?? all the dei alarms are the same basically. ------------- installers do it best. we got the magic hands!
Posted By: howie ll
Date Posted: February 09, 2010 at 2:43 AM
Unless this is new, you will have problems. It's a Cat, 4 wires for the immobiliser cuts, 2 grounds, main 5amp power and secondary 20amp power for indicators, ign stand off and two grounds = 9 wires, ALL BLACK. The rest are standard DEI colours. Also you wont be able to programme this without a Valet Code, it's unreadable with either Wiz or Bitwriter.DEI UK won't give you an install sheet unless you are a dealer. Also this sheet isn't available on Directechs. I got mine as an email from the tech side.
Posted By: golden2k10
Date Posted: December 25, 2010 at 2:48 PM
hi,
I know this is an old topic but am in need of the wiring diagram for this particular alarm. Thanks
Posted By: howie ll
Date Posted: December 25, 2010 at 4:41 PM
The above posts haven't changed, see above. Forget it unless you're a dealer.
