viper 5701 no serial or d2d?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=120044
Printed Date: May 28, 2024 at 6:14 PM
Topic: viper 5701 no serial or d2d?
Posted By: redz71tahoe
Subject: viper 5701 no serial or d2d?
Date Posted: February 11, 2010 at 2:07 AM
Just installed the Viper 5701 in an 05 Envoy with the DLPKGM. The DLPKGM went through the programming with the ignition key fine (the LED responded properly) so I’m assuming this would indicate the power is getting through the pink wire, and D2D cable, and that the purple vehicles data wire is hooked up properly. But the door locks don’t respond. My bitwriter rev (2.7) could see the 5701, (when I say it could see it, I mean it didn’t say “no device found” ) but it would hang on “reading from the device” , also tried with the D2D module unplugged, cycled power,, still no bitwriter access. Anyone else seen this?
Posted By: jeremytravis
Date Posted: March 18, 2010 at 12:37 PM
How did you wire up the module, W2W or D2D?
------------- **ADVANCED MECP CERTIFIED
Posted By: kgerry
Date Posted: March 18, 2010 at 2:40 PM
what is the date code of your 5701??
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
