09 malibu, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=120549
Printed Date: May 15, 2024 at 6:20 PM
Topic: 09 malibu, remote start
Posted By: 97gss
Subject: 09 malibu, remote start
Date Posted: March 06, 2010 at 8:47 AM
Any recommendations on a bypass module for this? Installing remote start. Thought about going with the CANMX400 but I wanted to see what your opinions are. Also would like a recommendation of where to buy one as well. I know some of you guys sell modules as well.
Posted By: stittville ed
Date Posted: March 06, 2010 at 1:08 PM
I just completed my wife's 2009 G6, which is the same car as far as the wiring goes. I used a Fortin CAN-SL2 along with a Viper 160XVL The Fortin needs no programing, works right out of the box. I had to call Fortin because I had a wrong connection and they helped me or should I say they told me what I had done wrong. Most of the connection are done before you get to the car between the Fortin and the starter. The biggest problem is to make the brake peddle connection. You are looking for a white wire in a bundle or wire with 5 white wires in it. I ended up taking the connector on the passengers side of the console and picking it up. Hope this helps you. ------------- Stittville Ed
Posted By: 97gss
Date Posted: March 06, 2010 at 8:46 PM
So this thing needs 2 modules? I thought the piece I mentioned did everything.
Date Posted: March 06, 2010 at 9:03 PM
The CAN-SL2 is the bypass and the Viper 160 is the remote start. About $50 for the bypass but I wasvery pleasd with it. ------------- Stittville Ed
Posted By: 97gss
Date Posted: March 07, 2010 at 9:13 PM
Oh ok. I'll look into that one as well. Thanks.
Date Posted: March 08, 2010 at 8:46 AM
Just make sure to check that the CANMX400 does not need any programing of flashing after you buy it. I think the downloads are free but you have to have a special cable/downloaded. As I said the Fortin worked right out of the box. ------------- Stittville Ed
Posted By: tedmond
Date Posted: March 08, 2010 at 2:26 PM
the fortin will still require a simple programming, but no need to flash it for a proper firmware. It comes preloaded for all vehicle it supports. ------------- Ted
Compustar Expert
Posted By: jim hunter
Date Posted: March 08, 2010 at 8:22 PM
these cars are very simple, just program a circle plus key in a coffin(556u or astcbm) ign and accessory@ ign switch, brake, neg pk lites,power,horn and locks in right side of center console as long as your remote starter (audiovox, dei) uses the proper ign acc sequence(acc first, ign 2nd, acc drop while ign stays) car is very simple, ive never used the fortin or the idatalink piece as i use audiovox starters and do em this way all the time with no issues
Posted By: alarep5
Date Posted: March 09, 2010 at 3:03 PM
I do a lot of this type car. I hardwire locks etc. I use a PKUGM2X usually. Very simple programing, put the key in turn it on for a couple seconds then remove it and remote start the engine-done. Otherwise you have to install a key and resistor wiring. ------------- OLDSCHOOL - If the wire is there,...use it.
Posted By: dmaclennan14
Date Posted: March 10, 2010 at 11:29 AM
this is the same way i install these. same way for a g6 or a cobalt(06 and up). this is the easiest way by far!
Posted By: 97gss
Date Posted: March 19, 2010 at 3:31 PM
Working on an 09 malibu and I can't find the door trigger wire to kill the RAP after the remote start shuts down. The 2 diagrams I have say it's either gray or gray/blk at the bcm. I've tested them all several times and either it has 12v with the door open(gray/blk) or they don't switch and stay at a very low voltage after the doors are closed and the light is off. I attempted to use a gray in the red plug at the bcm, which went to 12v after the lights turned off, but that didn't work. I'm intalling a prestige aps-57. Thanks.
Posted By: gabedemelo
Date Posted: March 19, 2010 at 3:48 PM
try tan if you take out the driverside fuse panel thing,... its there i think
------------- GreenGables
Date Posted: March 19, 2010 at 3:51 PM
ha sorry to sound so untechnical but the cover that would be flush against door f door were shut. i think you can see the bcm there,... maybe im thinking impala but either way try tan.
Posted By: 97gss
Date Posted: March 19, 2010 at 3:58 PM
just tried them. no go. They were in a flat gray plug. BCM is on the passenger side of the center console.
Posted By: 97gss
Date Posted: March 19, 2010 at 4:11 PM
Found it guys. It was the gray black after all. I must've tested it after the bcm timed out. :-(
