2005 toyota tacoma pkall
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=120711
Printed Date: May 18, 2024 at 4:15 PM
Topic: 2005 toyota tacoma pkall
Posted By: f00dstamps
Subject: 2005 toyota tacoma pkall
Date Posted: March 13, 2010 at 6:22 PM
Hey guys,
I am trying to install the PKALL into a 2005 Toyota Tacoma. I am having troubles finding the 7-pin connector that has the RX and TX data wires. Can anyone assist me? Thanks in advance.
Posted By: tedmond
Date Posted: March 13, 2010 at 6:37 PM
the 7pin connector is attached right at the key cylinder. you should see it right away. Pin 4 - RX Pin 5 - TX ------------- Ted
Compustar Expert
Date Posted: March 13, 2010 at 6:49 PM
if I post a picture of the ignition area, could you point it out to me?
Date Posted: March 13, 2010 at 6:53 PM
Posted By: kreg357
Date Posted: March 13, 2010 at 7:12 PM
It a black connector with 7 pins in a row. Pin 3 is empty and Pin4 (RX) is Pink/Green and Pin5 (TX) is Light GREEN/ Red. Should be on the ignition switch itself. Sorry, I don't have a picture and couldn't make it out on yours.
------------- Soldering is fun!
Posted By: tedmond
Date Posted: March 13, 2010 at 7:15 PM
looks like a prostart unit? anyways route the antenna wire and place the antenna on your windshield. I havnt seen the connector as black, but i have seen it as white on the canadian models. ------------- Ted
Compustar Expert
Date Posted: March 13, 2010 at 7:20 PM
I looked all around the ignition switch and I did not see any 7-pin connectors. I've performed about 10 RS installs so this isn't my first rodeo. I will snap some more detailed photos of the ignition switch. Is it possible that this 2005 Tacoma Access cab doesn't have an immobilizer?
Date Posted: March 13, 2010 at 7:29 PM
It's actually a Viper 5701. I am not done with the install yet but I plan on mounting the antenna on the windshield like you suggested.
Date Posted: March 13, 2010 at 7:34 PM
Posted By: kreg357
Date Posted: March 13, 2010 at 7:38 PM
2005 was the first year that the Tacoma got an immobilizer but it is possible that yours does not have one. What do the keys look like? Have you tried a remote start without the PKALL?
Date Posted: March 13, 2010 at 7:58 PM
I will try remote starting it without the pkall to see if it works. BTW, this Tacoma was purchased here in the US.
Date Posted: March 13, 2010 at 8:52 PM
well. I feel stupid. I should have known better but I made the assumption that all the 2005 Tacomas would have the immobilizer. This one started without a bypass. No wonder I couldn't find a 7-pin plug near the ignition. Thanks guys for your time.
Posted By: kgerry
Date Posted: March 15, 2010 at 10:45 AM
all you have to do is look for the immo ring at the ign switch, which your's obviously does not have.......
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
