f150 intermittent remote start?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=120797
Printed Date: March 20, 2026 at 9:59 AM
Topic: f150 intermittent remote start?
Posted By: deltadmx
Subject: f150 intermittent remote start?
Date Posted: March 18, 2010 at 9:35 PM
Hey guys,
Just did a 2005 F150 with an Ultra remote start and Fortin bypass. The install went smooth with no issues finding wires or making the connections. It appears every 5th or 6th time (rough estimate) the car will crank, start for a second, then die. The remote start will attempt to re-engage and run smoothly after that. To me it seems like maybe the bypass is at fault? Anyone have any ideas? The majority of the time it starts without any issues. Also, the remote start is auto-tached, maybe the auto-tach is causing the problem? I re-tach learned the system too.Thanks in advance!
Posted By: i am an idiot
Date Posted: March 18, 2010 at 9:59 PM
If auto-tach is the same as virtual tach, that is more than likely your problem. Connect the tach wire.
Posted By: tedmond
Date Posted: March 19, 2010 at 6:26 AM
ultra starts auto tach or virtual tach is not good at all. run anactual wire to the tach source.
------------- Ted
Compustar Expert
Posted By: deltadmx
Date Posted: March 21, 2010 at 3:15 PM
ran actual tach wire and she works like a champ - thanks guys!
