canmax400 and 2009 odyssey
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121019
Printed Date: June 07, 2024 at 11:53 PM
Topic: canmax400 and 2009 odyssey
Posted By: tillithz
Subject: canmax400 and 2009 odyssey
Date Posted: March 28, 2010 at 1:23 PM
has anyone interfaced these two? I am looking for the wire to wire application. I am also looking for what features are specifically available on the 09 as the manual from their site is not up to date for 09. Does anyone know? basically just the features available would be great, or if there is a better device thats be awesome as well. thanks in advance.
Posted By: tedmond
Date Posted: March 28, 2010 at 5:22 PM
never used the canmax but the idatalink pieces and fortin modules work vey well in my opinion.
------------- Ted
Compustar Expert
Posted By: brandonz
Date Posted: March 28, 2010 at 9:33 PM
I believe 2008 & 2009 are the same so it would do bypass, door locks, FAA, FAD, trunk release, sliding door control, door pins, trunk pin, and tach. I'd call DEI to verify.
Posted By: tillithz
Date Posted: March 28, 2010 at 10:33 PM
right on thank you. I think Im going with the idatalink because it actually is clear what features it supports. It also is nearly half the price. thanks again
Posted By: tedmond
Date Posted: March 29, 2010 at 6:45 AM
make sure whoever you buy it from can flash it with the correct firmware.
------------- Ted
Compustar Expert
