2002 DODGE RAM INSTALL
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12112
Printed Date: May 14, 2024 at 5:48 AM
Topic: 2002 DODGE RAM INSTALL
Posted By: CBR629
Subject: 2002 DODGE RAM INSTALL
Date Posted: April 12, 2003 at 11:18 AM
I put an alarm with remote starter in this vehicle,everything works fine but when the guy puts his ignition switch in the 'acc' position all of the lights on the dash come on as if he were ready to start the truck.I put diodes on the ignition wires from the remote starter and it still does the same thing...please help.
Posted By: auex
Date Posted: April 12, 2003 at 12:02 PM
You didn't hook up one of the alarms ing or acc outputs to both the acc and the ign? Also you should check the connections, if you soldered and taped, to make sure that there are no bare wires that could be touching somewhere. Also what type of alarm did you install?
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Velocity Motors
Date Posted: April 12, 2003 at 12:17 PM
When you installed the RS did you relay isolate the 2nd IGN & the 2nd ACC wires ?
------------- Jeff
Posted By: CBR629
Date Posted: April 12, 2003 at 8:59 PM
I used a excalibur alarm with remote starter,I had two ign wires from the remote starter and I had to add three relays.I added diodes from each wire off of the relays to power the other ign and acc wires
------------- THANKS
Date Posted: April 13, 2003 at 8:01 AM
Does the lights do that if you were to disconnect the Excalibur system from the harness ?
------------- Jeff
Posted By: Homicyde
Date Posted: April 13, 2003 at 10:16 AM
when you put the relays on the green and orange wires, you have to use a ground off the alarm thats only active when the remote start is running the engine, i had the same problem.....
------------- Homicyde-
Posted By: Brian Gaarder
Date Posted: April 13, 2003 at 3:04 PM
I dont know if this ios going to help but........ In 96 to 2001 dakotas the BLACK/ white wire in the ignition harness in NOT a second accessory wire ... its a second ignition wire..... if you connect a accessory wire to it it will cause the gauges to malfunction ........
