prestige aps 20b and aa 925 remotes
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121998
Printed Date: April 30, 2026 at 12:35 PM
Topic: prestige aps 20b and aa 925 remotes
Posted By: macpaul1
Subject: prestige aps 20b and aa 925 remotes
Date Posted: May 24, 2010 at 10:57 PM
I recently lost my keys with an APS-20B remote. Unfortunately, I only had one and did not ever find another one. Wanted to know if remotes for AA-925 were interchangeable with the APS-20B system. They look very similar in appearance and are a much newer remote and much more abundant online.
Alarm system is on a Dodge Ram '02 w/o remote start. Just a basic alarm system with shock sensor.
First time on this site, lots of good info. Thanks for your help in advance. If this doesn't work out, might even try installing a different system.
Posted By: blanx218
Date Posted: May 24, 2010 at 11:22 PM
from what i've seen in the past its worth trying to program if the LED is the same color. if they are both green or both red you should be able to program it. if they are opposite colors they wont work. hope this helps
Posted By: macpaul1
Date Posted: May 26, 2010 at 10:13 PM
Blanx218 - thanks for the help. Worth a shot to go ahead and order them. Thanks again.
