02 ford explorer factory alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=122262
Printed Date: June 09, 2024 at 8:24 PM
Topic: 02 ford explorer factory alarm
Posted By: oohdatbuck
Subject: 02 ford explorer factory alarm
Date Posted: June 11, 2010 at 7:21 PM
hey do anyone know how to reset a 02 Ford Explorer Factory Alarm. I was about to install my remote start and I took the steering wheel column off.Now my truck wont start it doesnt even click. Ford said that they have to program it and it'll run $100. Someone help me please
Posted By: roadshop570
Date Posted: June 11, 2010 at 8:03 PM
Was anything unplugged? even accidently, have you double checked the ignition harness, etc?
------------- Chadillac
Date Posted: June 11, 2010 at 8:12 PM
I unplugged a couple harnesses but im positive everything is back connected
Posted By: topinstaller200
Date Posted: June 11, 2010 at 8:43 PM
disconnect ground terminal from battery 3 minutes
does security light come on? All other accessories working? radio,lights, windows etc.
Date Posted: June 11, 2010 at 8:54 PM
nope nothing...only thing that comes on are my mirror lights and interior lights
Posted By: mikvot
Date Posted: June 11, 2010 at 9:11 PM
If the car is equipped with factory security, it would not prevent anything from working. Everything would work fine and the car would start as the turning the key in the ignition disarms the alarm. The immobilizer (which is seperate from the alarm) could prevent the car from starting, but would not prevent everything else from working....the truck would do everthing but start. It's easy to tell if it is the immobilizer. When you turn the key to the on position, there would be a red security light that would flash quickly. I would make sure the ignition harness is plugged in completely. If you have a multimeter, it would be easy to tell if this harness was getting 12 volts, and if this harness was sending out voltage correctly.
Date Posted: June 11, 2010 at 9:15 PM
i checked the harnesses and they are all hooked up but they are not getting any voltage. My batter is reading 12 volts. My door locks are working but when i turn the key i get nothing. no flashing light or anything. It was working fine until i unscrewed the steering column casing.
Posted By: mikvot
Date Posted: June 11, 2010 at 9:34 PM
I would start checking fuses then. Do not do a visual check. You will need to use a multimeter. Sounds like the fuse going to the ignition has blown. Do you have a multimeter?
Date Posted: June 11, 2010 at 9:41 PM
yea i checked the fuse it was good
Posted By: mikvot
Date Posted: June 11, 2010 at 9:49 PM
WHAT FUSE? You need to check every fuse in the vehicle. Once again...DO YOU HAVE A MULTIMETER? This fuse that you checked......did you do a continuity test on it? Either way....do not go by what the fusebox covers say...you need to test EVERY fuse in the vehicle.
Date Posted: June 11, 2010 at 10:36 PM
ok ill check every fuse and i will let you know the outcome....should there be a specific fuse in which i should be looking for
