04 tahoe, alarm, dlpkgm, door triggers?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=122277
Printed Date: October 31, 2024 at 7:15 PM
Topic: 04 tahoe, alarm, dlpkgm, door triggers?
Posted By: vince6411
Subject: 04 tahoe, alarm, dlpkgm, door triggers?
Date Posted: June 13, 2010 at 2:43 AM
I installed a Prestige APS-997N with the DLPKGM. This setup does NOT use the D2D so I have everthing connected as per the instructions. My problem is that I open the drivers door and the alarm works but when I open the trunck hatch or any of the other three doors the alarm dose not go off.
I not sure but I found this
https://64.85.6.118/diagrams/diagrams.asp
that said there are different places to hook up the door triggers for esch door. But with the DLPKGM I thought I only did the Green = -Door trigger output from DLPKGM to the BROWN = -Door Trigger INPUT on APS-997N.
Thanks Vince
Thanks to the members of this site I can do it!!! IT=EVERTHING
Posted By: ajstetler
Date Posted: June 14, 2010 at 12:36 PM
Only the front door triggers will work with this bypass. The rear doors and rear hatch must be grabbed at the BCM. The front doors are data, and the remaining triggers are analog. If you find a tech sheet, it will say to grab front door triggers at the module in the door, or use a bypass. Same with locks. Be sure to diode-isolate the rear doors.
Big Al
Posted By: topinstaller200
Date Posted: June 14, 2010 at 8:04 PM
the gray/black is a positive trigger that catches all, however domelight override switch cannot be turned off or will not protect.
Date Posted: June 16, 2010 at 10:57 AM
Thanks I just added a hood pin to the rear hatch and added it to the door - input on the alarm.
Date Posted: June 18, 2010 at 10:07 AM
So why even do it this way?! I'm not trying to be difficult, but this is NOT the correct way of doing door triggers on any vehicle unless absolutely needed. This vehicle is one of the easiest vehicles to do anything on, and that includes getting door triggers at the BCM. As installers, whether a newbie or experienced pro, we should take pride in our work and do things the correct way, not the "easiest".
Date Posted: June 18, 2010 at 1:09 PM
I saw this diagram last week but now after an hour of surching the forums I cant find it. Second thing is I have a set of 14 diff diodes that came with the alarm. all with a diff resistense. How do I test them to know which diode to use?
Installing alarm on a 04 tahoe
Date Posted: June 18, 2010 at 1:11 PM
I think i have 14 resisters and no diodes.
