2010 dodge caravan backup camera
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=122289
Printed Date: June 16, 2024 at 10:17 PM
Topic: 2010 dodge caravan backup camera
Posted By: paulmackie
Subject: 2010 dodge caravan backup camera
Date Posted: June 14, 2010 at 12:05 AM
Hi,
   is there an easy way to wire in the camera on the number plate of a 2010 dodge caravan? The camera kit says to place the camera above the number plate and wire the camera to the backup/reverse lights, how do you do that with a number plate in the middle of the hatchback?
Thanks Paul
Have a great day.
Paul
Posted By: awdeclipse
Date Posted: June 14, 2010 at 2:14 AM
Here's the Factory Install guide for the cameras installed aftermarket at the dealer (or elsewhere). You should find it very useful.
https://moparestore.trademotion.com/moparimages/accessory%20catalog/images/isheets/K6860480.pdf
Date Posted: June 14, 2010 at 9:59 AM
Hi,
    Thanks for the great info.
I have a Behindsight camera from Canadian Tire. the instructions say the camera easily mounts to the license plate, which it does, but is there a quick camera power connect in the lift up tail gate, or do I have to pull wiring to the reverse light on either side panel light assembly (which the instructions suggest)?
My guess is I would have to pull off all the trim on the tailgate and inside the van to the light assembly to power the camera.
The PDF really helps show what to do.
Thanks for the help.
Paul
Have a great day.
Paul
Date Posted: June 15, 2010 at 2:18 AM
You have to run all your wires up to the monitor up front anyhow so might as well follow the instructions I posted.
It shows where to get power and which wire is the Reverse wire. It doesn't look like much fun but at least its fairly well documented. Reminds me of IKEA instructions, all pics and no words. haha.
Enjoy.
Date Posted: June 15, 2010 at 9:26 AM
Hi,
   Thanks for all your info; it looks like an all day weekend job for me.
Just wondering where you get the type of information you posted?
Thanks again.
Paul
Have a great day.
Paul
