viper 5701, 2003 honda civic
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123023
Printed Date: April 17, 2026 at 12:24 AM
Topic: viper 5701, 2003 honda civic
Posted By: viffer
Subject: viper 5701, 2003 honda civic
Date Posted: August 08, 2010 at 7:46 AM
Hey guys,
I just installed a Viper 5701 into a 2003 Honda Civic and am having an issue I am hoping you can help me with...
I have most everything connected (except the power locks, that's next on the list)... When I connect the wiring harnesses to the brain I get nothing. No relay clicks, no LED flashes, nothing.
Any ideas of what I can check or test?
Thanks!
Posted By: viffer
Date Posted: August 08, 2010 at 7:53 AM
Hey guys,
I think I may be having an issue with my bypass module (Omega IB-H34). The unit is connected and does have power (as indicated by the LED when pressing the program switch). When I try to program the unit (depress program switch, turn ignition switch to on, wait for LED flash) the LED never flashes. It simply stays on, solid, for as long as you hold it. I get the same behavior when trying to reset it (disconnect connector, depress program switch, connect connector, wait for flash).
Any ideas before I send this back for RMA?
Thanks!
Posted By: viffer
Date Posted: August 08, 2010 at 7:54 AM
Sorry, I should have also mentioned this is installed in a 2003 Honda Civic.
Thanks!
Posted By: kreg357
Date Posted: August 08, 2010 at 11:34 AM
Do you have the bypass module connected as per the Type A instructions in the guide with good, solid, soldered connections? ( Did all the wire colors and pins match up? ) A bad ground could cause problems. Also a bad/missing ignition connection could cause it not to program. I usually get the ground, power and ignition from the same source as the remote start rather than the cars' transponder connector.
------------- Soldering is fun!
Posted By: viffer
Date Posted: August 08, 2010 at 12:09 PM
Hi thanks for the reply...
I do have the bypass module connected as per Type A instructions and all the wire colors did match up without an issue. The only wire on the module that was in question was the single brown wire with a connector on the end. That wire is not connected, along with the blue, BLACK/ white and green.
I have the alarm ignition wire (Pink) tapped in to the BLACK / YELLOW Ignition wire at the steering column.
Which wire actually feeds power to the alarm?
Here are my heavy gauge connections:
H3/1 PINK – (+) Ignition 1 input/ output -> BLACK / YELLOW
***Connect this wire to the ignition wire in the vehicle. This wire not only supplies voltage for the ignition line in the vehicle, it is also the ignition feed for the security system.
H3/2 RED / WHITE – (+) -> NC
***30a fused ignition 2/flex relay, pin 87, input.
This wire is the polarity feed for the ignition 2/flex relay.
H3/3 ORANGE – Accessory output. -> BLACK/ Red (Accessory 1)
***Connect this wire to the accessory wire that powers the climate control system
H3/4 VIOLET – Starter output. -> BLACK/ White (Started side of severed wire).
***This wire hooks up to the starter side of the starter wire in the car. This wire is also pin 30 of the onboard starter kill relay.
H3/5 GREEN – Starter input. -> BLACK/ White (Ignition side of severed wire).
***After cutting the starter wire connect the GREEN wire to the end going to the ignition switch. This wire is pin 87a of the onboard starter kill relay.
H3/6 RED – 30 amp fused Ignition 1 relay input. -> White (12v constant)
***This wire is the polarity feed for the Ignition 1 relay.
H3/7 PINK/WHITE – Ignition 2 flex relay output. -> WHITE/ Red (Second Accessory)
***This wire is factory programmed as Ignition 2 and can be programmed as a 2nd accessory or 2nd starter.
H3/8 PINK/BLACK – 87a of Ignition 2/Flex relay. -> NC
***This wire is used when an ignition switch isolation on the vehicle is necessary. This is common on Toyota and Nissans which required the use of Tech Tip document #1077. (See menu # 3 Feature 8 for programming options)
H3/9 RED / BLACK – 30a fused accessory/starter relay input -> NC
This wire is the polarity feed to the accessory and starter relays.
Posted By: kreg357
Date Posted: August 08, 2010 at 1:16 PM
The bypass brown will connect to the R/S's (-) Status Output ( aka Ground When Running ). That should not cause the reset or program problems if it's not currently attached..
On the H3 heavy gauge connecter, the Red, RED / Black & RED / White all get connected to a suitable constant +12 volt source. I am not a Viper expert but there is another +12volt supply wire on another harness that needs to be connected, H1/2 Red. ------------- Soldering is fun!
Posted By: viffer
Date Posted: August 08, 2010 at 3:27 PM
Out of curiosity, what is the R/S's?
Posted By: kreg357
Date Posted: August 08, 2010 at 3:37 PM
Sorry, my abreviation for remote start. The IB-H34 Brown wire would go the the Viper 5701 ( R/S ) 5 pin Remote Start Aux Output harness, Blue wire at Pin5, (-) 200mA Status Output.
Posted By: viffer
Date Posted: August 08, 2010 at 4:04 PM
Ok cool thanks for clarifying :)
Ok, you hit the nail on the head with the alternate (red) wire on H1. I missed it some how... The alarm now has power.
Now, as for the immobilizer bypass... Any ideas of what I could check? There really aren't alot of connections there... So there shouldn't be so much to screw up on that lol.
Posted By: kreg357
Date Posted: August 08, 2010 at 5:54 PM
I have a PKH34 in stock so I tried a reset on it with just the Red +12v and Black ground connected to the harness. It does the same as yours... LED stays red as long as the switch is held. I have used many of them in the past and found them easy to program and very reliable. Mostly on newer Hondas with the Install B for Type D cars. Not sure if mine is bad also but I doubt as it was in a sealed package. ( Don't think I ever tried a reset, they always programmed first try.)
Make sure the Brown wire isn't touching anything and double check the Purple data wire & connection. If you can, put a DMM on the Orange ignition wire and verify that gets +12v when you try to program it.
Posted By: viffer
Date Posted: August 08, 2010 at 8:49 PM
Ok, i'll give that a shot...
And thanks so much for going out of your way and testing that for me... That was very considerate of you!
Posted By: viffer
Date Posted: August 08, 2010 at 9:46 PM
Hey Guys,
I am installing a Viper 5701 into a 2003 Honda Civic with 4 after market 2 wire locks. How can I set up the progressive locks with this setup? I believe as far as I understand that I need 2 relays for standard lock/unlock feature... Would I require another relay?
Any tips or tricks you could share?
Thanks so much!
Posted By: viffer
Date Posted: August 10, 2010 at 1:16 PM
Ok I go the progressive locks thing figured out... pretty simple actually with 3 relays...
New Question...
When I press the start butting on the remote nothing happens. I have verified the hood pin is grounded and all my connections (listed on the first page of this post) are solid. Any ideas of where to start looking?
Thanks!
Posted By: kreg357
Date Posted: August 10, 2010 at 2:42 PM
Unless you changed the Hood Status option in Menu 1 - 11, the hood should show ground only when open. If it 's showing a ground then the remote start won't happen.
If your car is an automatic, did you change Menu 3 - 1 over to automatic?
When you say nothing happens when you press start, do the parking lights flash or the gagues come on?
Posted By: viffer
Date Posted: August 12, 2010 at 5:50 PM
Ok you got me on 2 points there... I had the hood pin grounded thinking I was showing the alarm a closed condition... Brain fart. And no, i didn't program the Auto mode... Doing that tonight. Thanks so much for the pointers.
Now, last question (hopefully):
Which wire should I connect the door trigger to as it seems each door is on an individual wire at the OEM alarm plug (The drivers door trigger is green, front passenger door trigger is lt. GREEN/ red, and the rear door trigger is GREEN / WHITE.)
And which wire (should i connect the dome light to?
Thanks again for all your help!
Posted By: kreg357
Date Posted: August 12, 2010 at 6:07 PM
The Civic has (-) negative door triggers. Use all four door triggers with diode isolation as per this link: https://www.bulldogsecurity.com/diagrams/extrainfo/diagrams/14301_CIVIC_(-)%20NEGATIVE%20DOOR%20PIN%20ISOLATION%20CIRCUIT.pdf Attach to the Viper (-) Door Trigger wire, H1/8 Green wire.
Posted By: viffer
Date Posted: August 12, 2010 at 10:41 PM
When trying to arm the system the system flashes the parking lights 7 times. Ideas?
Posted By: viffer
Date Posted: August 12, 2010 at 11:12 PM
Ok, a little reading would help on my part... After some searching on the internet I found 7 flashes means the alarm is in manual mode still. I guess it didn't take the program when I programmed it for automatic mode last time. Redid the program and now it works.
Thanks again for all your help. Very much appreciated.
Bill
Posted By: viffer
Date Posted: August 13, 2010 at 9:40 AM
Ok, I really hope this is the last post from me on this topic... this is dragging out way too long.
I am trying to program the progressive locks (Menu1,Function8)... I have set it to the second option and even the third out of desperation, but when I press the unlock button on the remote one the drivers door unlocks, but a second time does nothing. I believe the remote beeps twice but I hear nothing.
I wired everything up with 3 relays.
1 - unlock drivers door
2 - lock all doors
3 - unlock remaining doors
I wired them all identically using each trigger wire from the alarm.
Are there any glaring issues in my set up??
Posted By: t&t tech
Date Posted: August 13, 2010 at 5:31 PM
which wire form the viper unit did you use for the second unlock relay?
Posted By: viffer
Date Posted: August 13, 2010 at 11:53 PM
Blue
So primary lock/unlock is Blue and Green (only 2 wires on that connector) then the single blue wire from (I believe it's) H2.
