ref toyota hi luxe van
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123025
Printed Date: April 17, 2026 at 2:12 AM
Topic: ref toyota hi luxe van
Posted By: howie ll
Subject: ref toyota hi luxe van
Date Posted: August 08, 2010 at 12:20 PM
Wanted to add another sensor to a Toyota van apart from door triggers, wired a single zone prox to the dome light in the cargo compartment, wired to separate ground 12v+ and door trigger via a blocking diode.
It works but not enough juice to trigger the alarm. Right I'll add a mini relay (I make my own same as DEI 8616, but with a diode across the coil). Now it brings on the dome light BUT when you arm it it triggers the alarm! It wasn't doing that before I added the relay and it only does it when the dome light supervision has shut down and the dome lights are extinguished. N.B> There's already a Clifford G5 dual zone prox in the front that's been there some months.
Any thoughts?
Posted By: abethebue
Date Posted: August 08, 2010 at 5:10 PM
you might have to isolate cargo lamp wire but i think you have the diode reversed . might not need diode
abethebue
Posted By: howie ll
Date Posted: August 08, 2010 at 5:51 PM
I had the problem before I inserted the diode, it didn't change anything, next I dioded the power feed in case it was coming through the bulb. In fact it even happens when I remove the bulb!
This vehicle has separate trigger circuits, one for front doors and 1 for rear, but I noticed the front dome light came on when I opened the back doors, wonder if I screwed up the original install a year ago?
