04 sorento parking light flash
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124073
Printed Date: April 27, 2024 at 2:55 AM
Topic: 04 sorento parking light flash
Posted By: timo123451
Subject: 04 sorento parking light flash
Date Posted: October 22, 2010 at 8:53 PM
Just installed a Galaxy 2000 rs on my 04 Sorento. My parking lights will flash when locking and unlocking the doors with the remote if the headlight switch is in the off position. If the switch is in the on position and the vehicle is turned off it will not flash the parking lights. I changed the module to use the ground wire for the parking lights because I wasn't sure where to find the + wire. If I change it over to use the + wire will the lights work when the light switch is in the on position? Thanks
Posted By: pitoaudiovisual
Date Posted: October 23, 2010 at 10:26 AM
Not sure if it would stop but doesn't hurt to try. At the dimmer switch go to the RED / black wire which would be the positive one.
------------- Confidence is the key to any project!!
Posted By: Chris Luongo
Date Posted: October 24, 2010 at 11:18 AM
I never did understand why people with those cars leave the headlights on all the time.
But, the positive wire at the dimmer switch on the dashboard should work even if the light switch is left on.
Date Posted: October 24, 2010 at 8:07 PM
Thanks. I am going to try the other wire and see how it works out.
Date Posted: October 26, 2010 at 3:59 PM
I used the postive wire and everything works as it should. Thanks
