type a doorlock system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124190
Printed Date: February 05, 2026 at 6:53 AM
Topic: type a doorlock system
Posted By: tianot
Subject: type a doorlock system
Date Posted: October 30, 2010 at 1:33 AM
hello guys! how to connect a type A doorlock system?
correct me if im wrong.
the R/S unit has a (-) negative lock/unlock output right? and the vehicle has a positive output (+). how can i connect the wire?
do i need to use Two relays in order to convert the positive output to become a negative output?
87 & 85 - ground ?
86 - to vehicle (+) lock/unlock ?
30 - to R/S unit lock/unlock output ?
thanks
tianot
Posted By: howie ll
Date Posted: October 30, 2010 at 1:41 AM
R/S output lock to 85.
12V+ Constant via a 2amp fuse (shared with other relay) to 86 and 87
30 to vehicle lock wire.
Repeat for unlock.
Diode across each relay 1N4004, from 85 to 86, band towards 86.
Posted By: tianot
Date Posted: October 30, 2010 at 1:57 AM
thank howie,
i dont get it, do you have a schematic diagram for that doorlock system?
tianot
Posted By: howie ll
Date Posted: October 30, 2010 at 2:04 AM
No, just go to the relay section, this question and your multiple errors in the first post make me want to suggest read the relay and diode sections on this site or have it done professionally.
Posted By: howie ll
Date Posted: October 30, 2010 at 2:06 AM
Actually, look at the diagramme for "3 wire positive" door locks in the door lock section, top of this page.
Posted By: tianot
Date Posted: October 30, 2010 at 9:09 AM
hey howie!
thanks man, the 3 wire positive door lock is the right diagram if i have a positive lock/unlock?
tianot
Posted By: howie ll
Date Posted: October 30, 2010 at 9:12 AM
Yes.
