07 f 150 wont start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124214
Printed Date: May 06, 2026 at 11:59 AM
Topic: 07 f 150 wont start
Posted By: 07fx4
Subject: 07 f 150 wont start
Date Posted: October 31, 2010 at 4:50 PM
07 F-150 wont start...
My 2007 F-150 went into some sort of lock-up mode this morning after issues with auto-starting. I used my auto-starter to start the truck, then i put the key into the ignition and turned it to the "on" position, then i turned the key back to remove it and the truck kept running. Now the truck wont start with the autostart or the key in the ignition, it just keeps rolling and rolling.
Ive turned off the auto-starter under the dash, I've disconnected the battery for over an hour and still it wont start...
The auto-start is a "Mars" model made by Omega
ANYONE WITH ANY ADVICE???
Posted By: kreg357
Date Posted: October 31, 2010 at 4:56 PM
What type of bypass did you use?  Are there any dash security type lights on?
Posted By: 07fx4
Date Posted: October 31, 2010 at 4:59 PM
Im not sure, the auto-starter was installed before i Bought the  truck, no security lights that i can see are on...
The was running when i turned the key back and removed it, the truck kept running, i re-inserted the key to turn off the engine, the truck wouldnt start after that...
Posted By: kreg357
Date Posted: October 31, 2010 at 5:33 PM
How did you turn off the Omega Mars remote start unit?  Did you pull the fuses?
Check under the dash for a bypass module.  It might be powered independently from the remote start and still on.
Posted By: 07fx4
Date Posted: October 31, 2010 at 6:07 PM
I didnt pull any fuses, it only rolls the motor for so long and shuts off. If there is a bi-pass modual what should I do with it.?
Posted By: kreg357
Date Posted: October 31, 2010 at 6:27 PM
I would try pulling the fuses going to the Omega Mars unit first.  Also look for the bypass module.  Typically it is another slightly smaller unit that has wires going to the remote starter and the ignition switch area.
I am not familiar with the Omeaga units and their wiring or capabilities.  The are a lot of different bypass modules for your truck, even a "key wrap" is possible.
They problem could even be something like a fuel pump power cut relay controlled when the remote starter is locked  that has gone bad / become disconnected.
Posted By: 07fx4
Date Posted: October 31, 2010 at 7:29 PM
Im thinking it has something to do with the fuel pump or fuel delivery, cuz the truck rolls fine, just wont fire up...
Posted By: 07fx4
Date Posted: October 31, 2010 at 8:56 PM
But what I cant figure out is why this happened all of a sudden...is it possible I put my truck into some sort of "safe mode" or anti-theft mode?
Or do these kid of modes even exist?
Posted By: zerepdivad
Date Posted: October 31, 2010 at 10:24 PM
is the security light flashing when you attempt to start it?
A DMM is a beautiful thing.
Posted By: 07fx4
Date Posted: November 01, 2010 at 8:42 AM
The stock security light on the dash or the MARS Omega security light?
Posted By: kgerry
Date Posted: November 01, 2010 at 11:08 AM
the light on the dash (cluster)   the OE anti-theft system is a fuel shutoff system....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: 07fx4
Date Posted: November 01, 2010 at 6:40 PM
I took it to my garage, they say it needs a "fuel pump control modual", I hope they're right, as it will cost me around $450...
I still think the truck is in some sort of security mode tho...
Date Posted: November 01, 2010 at 7:07 PM
Well don't expect a refund if they're wrong.
Posted By: lgrammer
Date Posted: November 02, 2010 at 11:34 PM
sounds like the pats system. The keys have a chip in them and the vehicle isn't seeing them. when you turn the key to the on position is there a little security light that flashes constantly. i cant remember if it is a little light on the dash by the windshield or on the instrument cluster. Anyways if it is blinking then the keys either lost programming and the bypass on remote might be messing it up. You know the chip in the key is good when you turn it to the on position and that security light goes on solid for like 2 seconds then goes out.
