toyota rav4 2009
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124381
Printed Date: May 21, 2024 at 2:10 PM
Topic: toyota rav4 2009
Posted By: muaiad97
Subject: toyota rav4 2009
Date Posted: November 10, 2010 at 7:31 PM
Hi all
i installed compustar in this car 2009 rav every thing is ok exept the door lock  it lock all doors but it unlovk only driver door because this car need double pulse to unlock all doors and to disarm the factory alarm  during remote start  i need help please how to program the brain for double pulse using the tow way remote  not  use the programer  i dont have the programer the car is rav4   2009  ane it is compustar 5000 alarm and starter.
thanx
Posted By: kreg357
Date Posted: November 10, 2010 at 7:57 PM
Go to the "Downloads" section and search on "compustar".  Download the CM6000 manual ( The menu and procedure are the same as CM5000 ).  On page 19 it shows that Menu 1-04 needs to be changed for double pulse unlock.  Follow the steps on page 30 using your two way remote to change the setting to option 2.
Here is a re-cap:
The Menu setting you want to change is 1-04 to option 2.  Using a two way remote:
Option
Menu 1
(1 + 2) for 2.5 seconds then
Tap Button
4             Wait for confirming parking light flash or chirp
Do this 3 or 4  times to get to option group 1 feature 4 ( and get 4 Parking Light flashes ).
Tap Button
2             To select double pulse on unlock
Posted By: muaiad97
Date Posted: November 11, 2010 at 9:42 PM
thanx for replay and how about  reset to factory setting because the remote is locked now  any botten i push it says  FAIL.
thanx
Posted By: kreg357
Date Posted: November 12, 2010 at 4:30 AM
That should be in the CM6000 install guide also.  ( I have the OP500 and never use the remotes for programming.)  You can Factory Reset only one "Menu Group" at a time.
