connecting to hazard lights vs blinkers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124444
Printed Date: April 13, 2026 at 8:05 PM
Topic: connecting to hazard lights vs blinkers
Posted By: etang789
Subject: connecting to hazard lights vs blinkers
Date Posted: November 14, 2010 at 11:23 AM
I am uninstalling a Clifford 50.5x and replacing it with Viper 5901 on my Honda S2000.
The previous installer connected the parking light flash wire to the Hazard light, instead of connecting to the left and right blinker separately with diode. What problem will this cause whats the difference? Which way is better?
Posted By: corrado007
Date Posted: November 14, 2010 at 11:48 AM
Hey etang, I'm planning to install a 5902 next weekend and have a thread going for that install. I thought I'd share a few quotes from that thread that are somewhat relevant to your question. I'm still not perfectly clear on what the benefit to hazards would be over the standard parking light output. Sounds like it would be the same to me. I'll be following along here as well.
Chris Luongo wrote:
Turn on the hazards and listen for the factory flasher clicking on and off. When you locate it, look for the negative hazard flasher there.
If you connect your GREEN/ black disarm and GREEN / WHITE rearm wires to the hazards, you'll get flashes when you lock and unlock, similar to (but not exactly like) the factory setup. It'll also flash at remote start startup and shutdown.
howie ll wrote:
The hazards, we always wire the white to the hazards in Europe (or pos to GREEN/ black and GREEN/ YELLOW) 'cause everywhere but North America uses the AMBER lights as direction indicators, not white front and red rear because they are much easier to spot, thus on late Toyotas, neg feed to the neg wire at the hazard switch.
By the way, here's the link to the thread those quotes came from since we are basically installing the same alarm and some of the information may be of interest to you.
https://www.the12volt.com/installbay/forum_posts.asp~TID~124316~KW~5902+rav4~PN~1~TPN~1
Posted By: godd dan it
Date Posted: November 14, 2010 at 2:54 PM
I worked on a S2000 before. Cant remember what I did for the parking lights. Im pretty sure I went to the parking light wire somewhere under the dash, and its only 1 wire.
Posted By: howie ll
Date Posted: November 14, 2010 at 4:41 PM
Vehicles use amber indicators everywhere but North America. Corrado, with all respect why should a Honda be like a Toyota?
In fact you need to take the white wire from the unit, diode out in a "Y"** shape 1N5404 x 2, bands away from the alarm* set to + and joined to GREEN/ YELLOW and GREEN/ blue wires either Haz Switch, steering column loom or floor loom. That's how it's done everywhere but the US.
*If your unit states 10amp only power handling on that white wire you will need 1 relay + the diodes or 2 relays.
** In fact DEI package the two diodes, pre-joined via white cable for Europe on the US (basic) models it sells here.
Date Posted: November 14, 2010 at 5:32 PM
Hey there Howie,
I did not intend to suggest at all that a Honda is like a Toyota. It seemed to me that the original poster was asking what the difference is between hooking the parking light output to the hazard lights as opposed to the blinkers and which is preferable. I wondered the same thing in my 5902 install thread and some of the explanations I received, including yours, seemed relevant. My intent was not to direct him to use the wire colors that apply to my Toyota but rather to share the information surrounding it. He didn't seem to have any question about what wires to use so I didn't expect that the Toyota specific information would confuse him. Perhaps I misunderstood his question.
Posted By: howie ll
Date Posted: November 14, 2010 at 5:38 PM
OK Corrado, point taken, no offence meant, my toothache is acting up and I've been rather sarcastic with some incompetent people today.
OK etang, the 50X is I believe identical to your 5901, I believe the only difference is in the remotes so if it worked before, don't try to fix a non existent problem let it be!
Date Posted: November 14, 2010 at 6:44 PM
No offense taken Howie  . Sorry to hear your tooth is giving you trouble.
Posted By: t&t tech
Date Posted: November 14, 2010 at 7:19 PM
I think the guy wanted to know if connecting it with diodes would be better rather that the negative triger at the hazard switch, answer, either way is fine, no significant difference between them.
Date Posted: November 14, 2010 at 7:32 PM
I will take back what I said in my first post. I forgot the S2000 has side markers. So you can listen to the members that posted above.
When I install alarms, I like the corner lights (parking lights) to flash, not side markers. Do corner lights and side markers flash together? I didnt pay attention to that when I worked on the S2000. -------------
Posted By: etang789
Date Posted: November 14, 2010 at 9:27 PM
If you can do a install threat that would be great! Are you doing on a S2000 as well?
Date Posted: November 14, 2010 at 10:10 PM
I'm afraid I'm not working on an S2000, it's a RAV4 so I'm not sure a write-up for my car would be of much help to you. If you've got any specific questions though, I'm sure you'll be able to find an answer through a search or posting a question. There are also a ton of threads on the 5901 and 5902s if you'd just like to read over some general info on the unit. Sounds like you'll have a pretty easy time doing the swap since most if not all of the necessary wires will already have been located since you're disconnecting them from the Clifford.
Good luck.
