hyundai i30 2009 alarm wiring?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124650
Printed Date: June 02, 2024 at 10:35 AM
Topic: hyundai i30 2009 alarm wiring?
Posted By: colouny
Subject: hyundai i30 2009 alarm wiring?
Date Posted: November 25, 2010 at 8:39 AM
Does any1 has the alarm/remote start wiring for this car ? I am in desperate search...
------------- Car Audio and car security systems installer. Best in Car audio.
Posted By: i am an idiot
Date Posted: November 25, 2010 at 8:45 AM
Are you sure it is a Hyundai?
Posted By: tedmond
Date Posted: November 25, 2010 at 10:08 AM
if youre a "Car Audio and car security systems installer" you should be able to find all the wires you need within a few hours. You have half a donen wires down already which are at the ignition collumn.
rest are prob at kick panel or bcm of some sort. ------------- Ted
Compustar Expert
Posted By: colouny
Date Posted: November 25, 2010 at 11:11 AM
yup, pretty much.
wiki hyundai i30------------- Car Audio and car security systems installer. Best in Car audio.
Posted By: colouny
Date Posted: November 25, 2010 at 11:12 AM
I know, but if it uses canbus, then i need adapter, other wise, i will have to look for the wires my self.
Anyhow thanks, ;) ------------- Car Audio and car security systems installer. Best in Car audio.
Posted By: howie ll
Date Posted: November 25, 2010 at 12:48 PM
This and its Kia equivalent are made in Eastern Europe for the European market.
They are perceived as long lasting hatches for older people, sub Focus and Golf but much better built than anything from the likes of Renault, Peugeot/Citroen and Fiat.
Having said that going on my own experience with smaller versions, remove instrument panel and drop the steering column.
Instrument panel will give you feeds for the hatch, door triggers and left/right indicators via the warning lamps, + space (probably) to mount the control unit and wiring making it inaccessible to your thief, also allows you to access the steering column ignition etc. wires. Use a 556U by-pass, it's adequate. Door lock controls are down in the driver's kick well a la Toyota and at a guess are neg pulsing. (Give me a Japanese or Korean sourced vehicle that isn't neg).
There, job done.
Posted By: t&t tech
Date Posted: November 25, 2010 at 4:11 PM
It's actually a nice hyundai, if i might say so, (and i despise hyundai), worked on one a while back, wasn't to hard but no info, sorry, i was working outside of my work premises, couldn't take notes.
Posted By: colouny
Date Posted: November 28, 2010 at 11:51 AM
i must agree, it wasnt hard, no canbus. took 3 hours, to install alarm. As usual i forgot to take notes... cheers ------------- Car Audio and car security systems installer. Best in Car audio.
Posted By: t&t tech
Date Posted: November 28, 2010 at 12:16 PM
Cheers man, nice to meet ya, i see you've been here longer than i have, but it's the first time i've seen you around. Stick around this place gets better with every passing day.
Posted By: colouny
Date Posted: November 28, 2010 at 12:18 PM
Thanks, been longer, but i am a searcher not a poster. 95% of problems may be solved by searching! but i will try to do my best... ;) ------------- Car Audio and car security systems installer. Best in Car audio.
Posted By: howie ll
Date Posted: November 28, 2010 at 12:52 PM
Good attitude, I think it's a Kia Ceed in the US, was I right about dropping the inst. panel? We have both in the UK, I hate the Hyundai because of the massive "H" on the steering wheel, I had to live with one for three days last summer.
Posted By: colouny
Date Posted: November 28, 2010 at 1:09 PM
:D :D, i dont like them either. I drive Honda civic for last 8 years, i have rebuilt the engine like 3 times, and still dont want to sell the car. tho it became too expensive to drive it even with LPG. Then i decied that i need SMART CDi for the city driving. ------------- Car Audio and car security systems installer. Best in Car audio.
Posted By: howie ll
Date Posted: November 28, 2010 at 1:35 PM
Smart car, not too bad for an alarm etc. once you get to know it. Smart coupé, an absolute swine! At least as a right hand drive, the fusebox/control unit is above the pedals, you have to squirm in over the door sill to get at it, a nightmare.
Posted By: colouny
Date Posted: November 28, 2010 at 1:44 PM
Never had to install an alarm to SMART coupe... Some how they are not very popular over here...
it's about the peugeot or citroen cars, its impossible to dissanble anything, not speaking about same color cales with strange numbers.... :D
I personally think that if a car is to be stolen it will be, and no alarm car save it from its destiny... (this is what i have written on my garage wall). ------------- Car Audio and car security systems installer. Best in Car audio.
Posted By: howie ll
Date Posted: November 28, 2010 at 2:23 PM
We are of exactly the same mind ref: Cit/peugeots. In England we think French cars are CRAP it stands for CitroenRenaultAndPeugeot. It also means something else that you might tread in in English slang.
Then you work on an Alfa Tomeo and you will think that French cars are well made. Don't these manufacturers ever take a Honda or Toyota apart?
You should search some of my comments here about them.
Posted By: colouny
Date Posted: November 28, 2010 at 2:29 PM
100% Agree with you. I am trying to avoid them as much as i can. But i like to work with them when i have to deal with can bus. By the way French seems are from other planet when making cars...
By the way all cars are perfectly engineered, just right to that moment when the warranty ends... & the repairs are not for free :) (IMO) ------------- Car Audio and car security systems installer. Best in Car audio.
Posted By: howie ll
Date Posted: November 28, 2010 at 2:50 PM
Could it be that after the end of the Sovs, those Russians who designed the T55/72 went to work in France and Italy?
Posted By: colouny
Date Posted: November 28, 2010 at 2:59 PM
Probably true! They never learn from their mistakes, nor the Russians or French ------------- Car Audio and car security systems installer. Best in Car audio.
