2010 ford f150 door trigger wire issue
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124925
Printed Date: June 10, 2024 at 1:55 PM
Topic: 2010 ford f150 door trigger wire issue
Posted By: desh187
Subject: 2010 ford f150 door trigger wire issue
Date Posted: December 09, 2010 at 1:29 AM
Installed alarm/auto start on a 2010 2 door f150 and everything works fine except the door trigger.I used the gray/violet(+)at the sjb in passenger kick panel.This wire gives false trigger and sets the alarm off.I tried to switch to individual negative triggers but these wires are (n.c)and do not trigger the alarm when the doors are opened.It needs diodes and a resistor setup which i need more info on.driver door-GREEN/ violet,pass-white.
Any feedback will be much appreciated.Thanks
Posted By: KarTuneMan
Date Posted: December 09, 2010 at 1:45 AM
Use a bypass that will give you door monitoring.... otherwise get yer diodes and resisters out!
Posted By: cruzinlow
Date Posted: December 13, 2010 at 9:12 PM
Hi KarTuneMan,
i have always done newer the F-150's with diodes on all the individual negative door triggers (2 & 4 door). I have not yet seen a bypass for a Ford that does convenience features like the door triggers/status. If you have seen or used one, can you provide the info? Thanks!
Posted By: tedmond
Date Posted: December 13, 2010 at 9:42 PM
idatalink or fortin got that covered
------------- Ted
Compustar Expert
Date Posted: December 14, 2010 at 12:13 AM
Thank you sir Ted !!!
Posted By: howie ll
Date Posted: December 14, 2010 at 12:27 AM
DEI DTIMazda, also 5902s can be programmed for open circuit door triggers.
Date Posted: December 14, 2010 at 6:07 AM
Hey guys, thanks for the responses. I use idatalink all the time, and Fortin on occasion. Neither one actually provides a door status output for the F-150's. I know their modules can do it on other vehicles, just not this one. The DTIMazda still requires you to find all of the door triggers, correct? Any other suggestions is appreciated.
Posted By: dcman41
Date Posted: December 14, 2010 at 10:28 PM
