mazda p/u battery rundown protection
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125400
Printed Date: May 15, 2026 at 7:39 AM
Topic: mazda p/u battery rundown protection
Posted By: condorosa
Subject: mazda p/u battery rundown protection
Date Posted: January 02, 2011 at 7:31 AM
Hi
I would like to alter the basic wiring to the headlights & park-lights on a 1995 Mazda pick-up to prevent battery rundown when the headlights etc. are accidentally left on.This vehicle has only electronic ignition, no alarm or engine management system. Any advice & wiring diagram would be appreciated.
Posted By: chev104275
Date Posted: January 02, 2011 at 7:37 AM
You could open the power wire to the headlight switch with a relay and have the relay only enerigize when the key is in the on position. That way the headlights would only work when the key is on And shut off when the key is off
Posted By: howie ll
Date Posted: January 02, 2011 at 7:58 AM
Or a buzzer powered by either side or head lights power feed, grounded via the driver's door trigger.
