2002 Dodge Dakota Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125449
Printed Date: May 21, 2024 at 4:21 AM
Topic: 2002 Dodge Dakota Remote Start
Posted By: bryanrt360
Subject: 2002 Dodge Dakota Remote Start
Date Posted: January 04, 2011 at 2:11 PM
I have a few questions maybe you guys can answer for me. I have a 2002 Dodge Dakota. I want to install a remote start. I have the avitial 4103.
1. the Direct wire 2.0 printout say my locks are a negative trigger. 820ohm resistor for lock and 330 ohm for unlock. also it says MUST use relays.. can some one draw me a diagram for the relays? can some one draw me a diagram for the relays? Also does it matter what watt the resistors are?? 1/4, 1/2, 1/8w??
2. Parking lights. The Directwire sheet says I have 2 wires for the parking lights. how to I hook thes up?and How do I know if the light system draws more than 10amps??( I'm guessing I can figure this out by checking the fuse.)
Date Posted: January 04, 2011 at 2:27 PM
Also the directwire sheet says i have a "lock motor" wire. is this needed?
Thanks Guys
-Bryan-
Posted By: kreg357
Date Posted: January 04, 2011 at 2:36 PM
For the door locks, here is a diagram from Bulldog Security. The top diagram is correct for a remote start with (-) lock outputs. The lock motor wire is not necessary.
For the Parking Lights both Bulldog Security and Audiovox say BLACK / YELLOW (+) at the headlight switch.
Bulldog: PARKING LIGHTS ( + ) BLACK / YELLOW (+) @ HEADLIGHT SWITCH
Audiovox: Parking Lights BLACK / YELLOW (+) HEADLIGHT SWITCH
------------- Soldering is fun!
Posted By: Twelvoltz
Date Posted: January 04, 2011 at 2:41 PM
1. Lock:
Pin 86 green lock output from 4103
Pin 30 ground with 820 ohm resistor inline
Pin 85 Fused constant +12V
Pin 87 WHITE/ green wire in truck
Unlock:
Pin 86 blue unlock output from 4103
Pin 30 ground with 330 ohm resistor inline
If you pick up a 451M DEI door lock relay pack it will plug right into the door lock port on the brain of your system, and include all required resistors. It's a lot smaller than 2 standard relays too. They are inexpensive IMO ($7 on ebay shipped.)
2. The two wires listed for your 2002 Dakota are options you have for hooking up the parking lights, either will work. You can trigger them either with a negative (RED / yellow at CTM) or positive trigger (BLACK / YELLOW at CTM). In most new vehicles I hook up using negative trigger whenever possible, but your ignition wires supply enough to use the BLACK / YELLOW at the headlight switch...just hook your white parking light output to it and you will be fine. The included 10amp fuse is plenty to supply the parking lights.
You do not need to concern yourself with the actuator wires (motor wires). This information is useful for remote starts being activated without their own keyfob and for progressive unlocking...neither of which really apply to your particular setup using the 4103.
------------- Installer, IT support, and FFL. I need less hobbies.
Posted By: monty_77
Date Posted: January 04, 2011 at 2:49 PM
any resistor watt size will work
for the park lights it a single positive wire BLACK / YELLOW at back of fuse box will work
if you want pics of this truck pm me or email me
Date Posted: January 04, 2011 at 2:54 PM
WOW.. Thanks a bunch guys for the quick replys
Posted By: monty_77
Date Posted: January 04, 2011 at 3:23 PM
Your welcome if you need any more help posts some more
i do have detailed pic on the wiring of this vehicle if you need them
Date Posted: January 04, 2011 at 3:42 PM
ok, another question. Neutral safety switch. manual says to download "Document 1008" from the directed site.. I dont have access.
I'll take a lot at those pics if you dont mind.
Btschroer@comcast.net
Posted By: monty_77
Date Posted: January 04, 2011 at 6:15 PM
I sent you both the pic and the document
I think most people in automatics just wire it to a ground
Also it you are looking for document and manuals for anything you may want to search the downloads section it might all ready be there doc 1008 was not there
Date Posted: January 04, 2011 at 6:55 PM
the pics are perfect! this is gonna be a breeze.
ok. last question..
on the pdf from directed, it say my truck is a transponder vehicle. I didnt think it was. I have a black key, non-security. I thought the transponder's were with the gray "skim" key that had factory security.
Posted By: monty_77
Date Posted: January 04, 2011 at 7:08 PM
if its the black key you are good to go not all the dodge had the sentry key at that time if it not gray it does not have a transponder in it
Date Posted: January 04, 2011 at 7:09 PM
ok. last question..
nevermind. My truck is NOT a transponder vehicle.
Posted By: gmc8757
Date Posted: January 05, 2011 at 1:21 PM
Hey Guys. I'm looking at the wiring for a 2002 Dakota and it is showing 3 ignition wires. What did you do with the 3rd ignition wire? I know for example the Ultra Start has room for 2 ignition wires?
Posted By: gmc8757
Date Posted: January 05, 2011 at 1:27 PM
Sorry, should have been clear. I saw the wire diagram that shows 3 ignition wires on Bulldogs site. https://www.bulldogsecurity.com/diagrams/printpage.asp?ModelID=13847&MakeID=16
But now I'm looking at another diagram from Directed and it's only showing 2 ignition wires.
Posted By: monty_77
Date Posted: January 05, 2011 at 2:53 PM
i checked direct wire and they only show the 2 ignition wires too dk blue and small dk GREEN/ red
2002 Dodge Dakota DirectWire 2.0 Vehicle Information
All Products
Item Wire Color Polarity Wire Location
12 Volts pnk/blk & RED / lt blu + ignition harness
Second 12 Volts
Starter yellow + ignition harness
Second Starter
Ignition blue + ignition harness
Second Ignition GREEN/ red (18 ga) + ignition harness
Third Ignition
Accessory BLACK/ orange + ignition harness
Second Accessory green + ignition harness
Third Accessory
Keysense
Data Bus
Can Bus High
Can Bus Low
Can Bus Sw
Power Lock WHITE/ green - conn. 2, pin 10 @ CTM
Lock is negative trigger thru a 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays. The Central Timer Module is in the driver kick panel.
Power Unlock same wire
Lock Motor ORANGE / black conn. 2, pin 4 @ CTM
Driver Unlock Motor blue conn. 2, pin 6 @ CTM
Passenger Unlock Motor pink/black conn. 2, pin 5 @ CTM
Parking Lights (-) RED / yellow conn. 1, pin 4 @ CTM
Parking Lights (+) BLACK / YELLOW headlight switch
Hazards
Turn Signal (Left)
Turn Signal (Right)
Headlight lt. GREEN/ orange - headlight switch
AutoLights
Reverse Light
Left Front Door Trigger - CTM
The Central Timer Module is in the driver kick panel. The driver door trigger is tan in connector 2, pin 15. The passenger door trigger (and rears on the 4dr) is tan/red in connector 2, pin 13. Use both and diode isolate each. See directfax document #1076 for wiring information.
Right Front Door Trigger
Left Rear Door Trigger
Right Rear Door Trigger
Dome Supervision use door trigger
Trunk/Hatch Pin
Rear Glass Pin
Hood Pin
Trunk/Hatch Release
Trunk Release Motor
Fuel Door Release
Power Sliding Door (Left)
Power Sliding Door (Right)
Factory Alarm Arm lt. GREEN/ orange - conn. 2, pin 14 @ CTM
Arm is negative trigger thru a 644 ohm resistor. Disarm is negative trigger thru a 1565 ohm resistor. MUST use relays. This wire will also lock the doors, and it will unlock with a double pulse. The Central Timer Module is in the driver kick panel.
Factory Alarm Disarm same wire
Disarm No Unlock
Trunk Alarm Shunt
Tachometer ignition coil
On the 2.5L/3.9L/5.9L models use BLACK/ gray at the ignition coil. The 4.7L models have an ignition coil for each cylinder, use the wires that is NOT GREEN/ orange at one of the coils.
Wait to Start
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Left Front Heated Seat
Right Front Heated Seat
Speed Sense WHITE/ orange or blue conn. 2, pin 27 @ PCM
The Powertrain Control Module is on the passenger fender.
Brake Wire WHITE/ tan + brake pedal switch
Parking Brake
Horn Trigger BLACK/ red - steering column or CTM
Wipers purple(L), RED / gry(H + steering column
Left Front Window (Up/Down) lt. blue - white A driver window switch
Right Front Window (Up/Down) brn/wht - pur/wht A driver kick panel
Left Rear Window (Up/Down) blu/wht - RED / blk A driver kick panel
Right Rear Window (Up/Down) gry/blk - grn/wht A driver kick panel
Sun Roof (Open/Close)
Sun Roof (Limit/Close)
Memory Seat 1
Memory Seat 2
Memory Seat 3
Radio 12V pink + radio
Radio Ground black - radio
Radio Ignition RED / white + radio
Radio Illumination white + radio
Factory Amp Turn-on
Power Antenna
Left Front Speaker (+/-) lt grn/pu-lt grn/grn radio
Right Front Speaker (+/-) lt blu/pu-lt blu/blk radio
Left Rear Speaker (+/-) wht/red - wht/blk radio
Right Rear Speaker (+/-) tan/pur - tan/blk radio
Center Channel (+/-)
Subwoofer (+/-)
Aux. Audio Input Left (+/-)
Aux. Audio Input Right (+/-)
RSE Video (+/-)
RSE Audio Left (+/-)
RSE Audio Right (+/-)
Satellite Radio 12 Volts
Satellite Radio Ground
Satellite Radio Ignition
Satellite Radio Antenna
Satellite Audio Left (+/-)
Satellite Audio Right (+/-)
Item Size Depth Location
Headunit
Left Front Speaker
Left Front Tweeter
Right Front Speaker
Right Front Tweeter
Left Rear Speaker
Left Rear Tweeter
Right Rear Speaker
Right Rear Tweeter
Center Channel
Subwoofer
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner
Smart Starter Kill Relay
Relay Type:
Part #:
OE Relay Part #:
n/a
n/a
n/a
Notes:
n/a
Alternate Part Notes:
n/a
Interface Modules
SKU Module Description Upgradeable Keys Required for Programming Keys Required for Operation
Posted By: gmc8757
Date Posted: January 05, 2011 at 3:15 PM
I see it is real easy to get to a tach wire on the 4.7 L. But what about all the other Liter Dakotas? Would you have to go to the ignition coil? I see you have to take the air filter out to get to the coil, just wondering if there is an easy place to get the tach wire?
Posted By: monty_77
Date Posted: January 05, 2011 at 6:56 PM
you should be able to use any uncommon wire on an injector too
Posted By: gmc8757
Date Posted: January 06, 2011 at 7:39 AM
Sorry for the question, I really appreciate your help. But how do I know if it's an "uncommon wire"? Or what an Uncommon wire is?
Posted By: kreg357
Date Posted: January 06, 2011 at 8:14 AM
Most Fuel Injectors have two wires. if you inspect several injectors, you will notice that they all have one wire that is the same color, but each injector has a unique colored wire. That unique colored wire is the one you want. Verify with a Digital Multi Meter set to 20V AC. The reading should be between 1 - 6 volts at idle and rise with RPM's.
Posted By: gmc8757
Date Posted: January 06, 2011 at 8:18 AM
Awesome! thank you very much..information
Posted By: gmc8757
Date Posted: January 06, 2011 at 8:46 AM
Just to make sure, you mean put the multi meter setting to 20V DC right?
Posted By: monty_77
Date Posted: January 06, 2011 at 10:52 AM
no you will need one with AC setting on it
Posted By: kreg357
Date Posted: January 06, 2011 at 12:43 PM
Tach signals are checked as AC voltages. A DMM with a Frequency setting is OK too.
Date Posted: January 06, 2011 at 7:26 PM
Success!! everything works like it should. Thanks again for all the info
Date Posted: January 12, 2011 at 11:31 PM
I just try to sent you a PM. inbox must be full.
Do you have a detailed pic for a 2006 nissan maxima?
Bryan
Posted By: monty_77
Date Posted: January 13, 2011 at 12:51 AM
clean out inbox
Posted By: micky-b
Date Posted: November 13, 2011 at 8:11 PM
Hi guys.
Looking for a little help with a 2002 Dodge Dakota, I have installed a Autopage 665-2W, everything works, well almost everything, when I try to remote start I just get 3 beeps from the transmitter, nothing else, no relays kick in or anything, I have re-checked the wiring and it all looks good, I followed the wiring guide in this topic. I have a black key no transponder / immobilizer.
Any help would be appreciated..
TIA
Posted By: monty_77
Date Posted: November 13, 2011 at 8:59 PM
Are you positive you have the remote starter in auto and not manual transmission.
Also make sure that your have the neutral safety wire hooked up that some remote starts have
Posted By: micky-b
Date Posted: November 13, 2011 at 9:32 PM
The Autopage unit is designed only for Automatics, the neutral safety wire was wired straight to ground..
