1998 civic viper 5701
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125460
Printed Date: May 26, 2024 at 9:13 AM
Topic: 1998 civic viper 5701
Posted By: xbimmer
Subject: 1998 civic viper 5701
Date Posted: January 04, 2011 at 9:01 PM
1998 Civic Lx (4 doors) Automatic
Viper 5701
USED THIS DIAGRAM
Connection:
*Primary(h1) 12-pin
H1/1 RED / WHITE (-) 200mA TRUNK RELEASE OUTPUT not used
H1/2 RED (+)12v CONSTANT INPUT White
H1/3 BROWN (+) SIREN OUTPUT red on siren ( grounded black to chassi of car)
H1/4 WHITE/ BROWN LIGHT FLASH -ISOLATION WIRE not used
H1/5 BLACK (-) CHASSIS GROUND chassis ground
H1/6 VIOLET (+) DOOR TRIGGER INPUT not used i mine is (-)
H1/7 BLUE (-) TRUNK PIN/ INSTANT TRIGGER INPUT Radio Light Green (-)
H1/8 GREEN (-) DOOR TRIGGER INPUT Light GREEN/ Red (-)
H1/9 BLACK/ WHITE (-) 200mA DOME LIGHT OUTPUT lt green /black factory alarm plug
H1/10 WHITE/ BLUE (-) REMOTE START/ TURBO TIMER ACTIVATION INPUT not used
H1/11 WHITE PARKING LIGHT OUTPUT not used turned off in settings
H1/12 ORANGE (-) 500mA GROUND WHEN ARMED OUTPUT not used
*Auxilary harness (H2) 8 pin **DIDNT USE ANY***
H2/1 LIGHT GREEN/ BLACK
H2/2 LIGHT GREEN/ WHITE
H2/3 WHITE/ VIOLET
H2/4 VIOLET/BLACK
H2/5 WHITE/ BLACK
H2/6 LIGHT BLUE
H2/7 GRAY/BLACK
H2/8 BROWN / BLACK
(-) 200mA FACTORY ALARM DISARM OUTPUT
(-) 200mA FACTORY ALARM ARM OUTPUT
(-) 200mA AUX 1 OUTPUT
(-) 200mA AUX 2 OUTPUT
(-) 200mA AUX 3 OUTPUT
(-) 200mA 2ND UNLOCK OUTPUT
(-) DIESEL WAIT TO START INPUT
(-) 200mA HORN HONK OUTPUT
Door lock harness 3 pin
1 Blue + lock GREEN / WHITE driver kick blue plug ( source of wire color direct wire)
3 green - unlock GREEN/ orange driver kick blue plug ( source of wire color direct wire)
*Heavy Gauge remote start (h3)
1 PINK (+) IGNITION 1 INPUT/OUTPUT Ignition BLACK / YELLOW
2 RED / WHITE (30A) FUSED IGNITION 2 / FLEX RELAY INPUT 87 Constant 12V+ White
3 ORANGE ACCESSORY OUTPUT Accessory WHITE/ Black
4 VIOLET (+) STARTER OUTPUT (CAR SIDE OF THE STARTER KILL WIRE) Starter BLACK/ White
5 GREEN (+) STARTER INPUT (KEY SIDE OF THE STARTER KILL WIRE) Starter BLACK/ White
6 RED(+) FUSED (30A) IGNITION 1 INPUT Constant 12V+ White
7 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT Ignition 2 Yellow programed in settings as ignition 2
8 PINK/BLACK FLEX RELAY INPUT 87A key side (if required) of FLEX RELAY not used
9 RED / BLACK FUSED (30A) ACCESSORY/STARTER INPUT Constant 12V+ White
*Remote start input 5 pin*
1 BLACK/ WHITE (-) NEUTRAL SAFETY SWITCH INPUT connected to wire h1/5 which goes to chassis
2 VIOLET/WHITE TACHOMETER INPUT WIRE blue wire behind tach that read voltage when tach worked and when i disconected it tachometer stoped working
3 BROWN (+) BRAKE SHUTDOWN WIRE GREEN / WHITE brake switch
4 GRAY N/O or N/C (-) HOOD PIN SWITCH INPUT, ZONE 6 to hood pin
5 BLUE/WHITE (-) 200 mA 2ND STATUS/REAR DEFOGGER not used
Remote start aux output 5 pin **didnt not use any
Note: Wires 1 - 4 on the remote auxiliary outputs are wired to the (-) triggers for the onboard remote start relays and are not diode isolated. If wiring these wires directly to the vehicle you must place a 1-amp diode in line to prevent feedback from the vehicle.
1
PINK/WHITE
(-) 200mA FLEX RELAY CONTROL OUTPUT
2
ORANGE
(-) 200mA ACCESSORY OUTPUT
3
VIOLET
(-) 200mA STARTER OUTPUT
4
PINK
(-) 200mA IGNITION 1 OUTPUT
5
BLUE
(-) 200mA STATUS OUTPUT
My question:
car does remote starts, remote shuts off , alarm works , doors unlock ,locks .
Only thing
2 way remote doesnt show confirmation.
when i press something like lock ,it locks the car but gives me at first F led solid and orange led flashes
then in few seconds beeps 2 times with F led 4 times like: ty dy ....few seconds pause ty dy ....pause .... ty dy....pause ... ty dy
also when i unlock siren chirps twice then in few seconds one more chirp .
when i lock only once.
Please help .
USED THIS DIAGRAM
Posted By: tedmond
Date Posted: January 04, 2011 at 10:08 PM
reset the brain by removing all fuses for 30 seconds.
------------- Ted
Compustar Expert
Posted By: xbimmer
Date Posted: January 04, 2011 at 10:16 PM
just did it tried twice first 30 sec , 2nd time 1 min , same no change :( ( also bought new battery for remote.
Posted By: tedmond
Date Posted: January 04, 2011 at 10:53 PM
you most likely have a defective remote then.
i ran into the same problem awhile back, had to buy new remotes ------------- Ted
Compustar Expert
Posted By: xbimmer
Date Posted: January 04, 2011 at 11:00 PM
Ill try new remote at the end of week.
How does the wiring look? Any wire that needs to be connected?
I really appreciate your time.
Posted By: xbimmer
Date Posted: January 05, 2011 at 7:52 AM
any body else had /have this issue ? thxz
Posted By: tedmond
Date Posted: January 05, 2011 at 8:06 AM
wiring looks fine.
there were many issues with remotes not working, did you buy the unit online? ------------- Ted
Compustar Expert
Posted By: xbimmer
Date Posted: January 05, 2011 at 8:08 AM
Yes, but its covered under lifitime no hassle exchange.
Posted By: xbimmer
Date Posted: January 05, 2011 at 1:50 PM
I'm shipping the brain and remotes for testing and exchange, ill post back with results.
Posted By: smokeman1
Date Posted: January 05, 2011 at 5:54 PM
Out of the 20 or so 5301 and 5701 that I have dealt with, I had one that acted the way yours does. No matter what I tried, it remained funky. Replace it.
------------- When all else fails, Read the Instructions
Posted By: howie ll
Date Posted: January 05, 2011 at 6:05 PM
That second beep may even be a door or hood trigger not working properly, that apart your wiring is fine.
Posted By: xbimmer
Date Posted: January 06, 2011 at 5:19 PM
i just tested my friends remote , does the same but with out beeps after ,
so i shipped out the brain and remotes for exchange , thxz all , ill post back when new unit arrives.
now i need to figure that extra beep. ill do that after 2 way communication starts working .
Posted By: xbimmer
Date Posted: January 28, 2011 at 5:33 PM
Hey guys, that was brain problem , how everything works , any body can point me in right direction with door trigger , when i disconnect the wire (green- ) it doesn't chirp one more time after locking , and remote shows at the end one red with one green on very top.
what seems to be the problem ? or should i connect violet since mine (in civic is negative) ?
Posted By: howie ll
Date Posted: January 28, 2011 at 5:46 PM
Forget the violet, you don't use it.
Have you actually tested to make sure your door, trunk and add-on hood switches are working correctly?
You can programme it out anyway.
If it is the door contact switch, change to wiring to the door ajar indicator light on the instrument panel, it's more reliable anyway.
Posted By: xbimmer
Date Posted: January 28, 2011 at 7:29 PM
You wont believe it ,stupid of me , passenger door wasn't closed all the way. Works perfect.
thank you
Actually have 2 questions? when should i lear rpm when car is cold ,or warmed up ?
and how to you adjust the sensor sensitivity ? should i touch it at all ?
Posted By: tony_g
Date Posted: January 28, 2011 at 7:48 PM
i did the tach learn for my 5701 with the engine cold, if you let it warm up and learn at the lower idle then remote start in cold weather the engine idles high before settling down and the r/s assumes its over revving and shuts down. my shock sensor is set at 8 i cant really go higher as if i do it gets set off by pumped up pickups with the custom deep sounding exhausts.
Posted By: xbimmer
Date Posted: January 28, 2011 at 9:39 PM
so how do u set/adjust sensor ?
and i learned mine when its cold ,it works perfect so far.
Posted By: tony_g
Date Posted: January 28, 2011 at 11:53 PM
Adjusting the onboard shock sensor
The new Responder LE system has an onboard shock sensor that is
remote adjustable. Adjusting the onboard sensor can be performed
by an authorized dealer (recommended) or by a programmed remote
transmitter.
Transmitter adjustment:
Disarm the unit and exit Valet Mode if ON. Turn the ignition off and
close all entry points (door, hood, trunk).
Use the following steps to put the control module into sensor
adjust mode:
Press/hold the function button of the remote control for 8 seconds or
until the Amber LED turns on and you hear one long beep.
Press/hold the lock button 1.5 seconds or until the amber led flashes once:
The control module will emit one long chirp, enter adjust mode, and
send the current level of information back to the transmitter. The
remote will beep once and the button LEDs will turn on to indicate the
current level.
Press the Arm, Disarm, or Remote Start buttons to adjust the sensor
level.
Arm button: Pressing the arm button will increase the sensitivity one
level. The siren chirps twice, the remote beeps twice and the LEDs increase in level.
Disarm button: Pressing the disarm button will decrease the sensitivity
one level. The siren chirps once, the remote beeps once and the LEDs
decrease in level.
Remote Start button: Pressing the r/s button will reset to default
level 7. The siren chirp three times, the remote beeps three times and
the LEDs reset.
To exit the adjust shock sensor mode from the remote control:
Press the function button. The control module is exited.
To exit the adjust shock sensor mode from the control module:
Open an entry point or turn on the ignition, the control module will
emit one long chirp and tell the remote to exit adjust mode.
To exit programming:
Press and release the function button any time during programming to go
back to the main menu. Press and hold for 1.5 seconds in the main
menu to exit programming.
Posted By: howie ll
Date Posted: January 29, 2011 at 4:19 AM
X 3 with tony-g and xbimmer. it was an old Clifford trick to increase the idle revs from say 800rpm to 1100rpm whilst programming.
