2005 dodge ram, viper 5701
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125503
Printed Date: May 15, 2024 at 6:02 PM
Topic: 2005 dodge ram, viper 5701
Posted By: onemoosehorn
Subject: 2005 dodge ram, viper 5701
Date Posted: January 06, 2011 at 4:49 PM
Quick question everyone, I have a 2005 Dodge Ram 1500 that I am installing a viper 5701 in. Im good on most of the wiring except the parking light resistors. I need to know what the resistor size is. Is it 250, 330, or 590ohms? Im finding different answers when im searching. Im not using the headlights for the fact of my hid's. Just want the parking lights to work for remote start, lock and unlock, etc.
Also, can anyone clear up how many ignition and accessory wires this truck has that i need to use? From what I understand:
H3/1 Pink- Ignition
H3/3 Orange- Acc
H3/7 Pink/white- Ign 2
So, can I use H3/8 Pink/black flex relay as another ign, or do I have to connect the rest via the Remote Start Output connector along with relays? I have a wiring diagram from this site along with a couple other sites and they differ a little.
Thanks everyone
Posted By: pimpincavy
Date Posted: January 06, 2011 at 5:14 PM
Should be a 330ohm and you will most likely need to break the wire with a relay so the headlights dont turn on as well. That truck should have 2 ign wires pink/green and pink/white as well as 3 acc wires blue and 2 pink / YELLOWs. There should be 3 pink / YELLOW acc wires. You need the 2 that do NOT come on when the key is in the back position. Does your starter have a negative acc output, or just the status out?
Date Posted: January 06, 2011 at 6:14 PM
On the Remote Start Output connector? It has an Orange, RS Accessory (-) 200mA output..
Date Posted: January 06, 2011 at 8:06 PM
So something like this:
H3/3- Orange to Blue Acc of truck
Remote Start Output connector- Orange RS Acc (-) to 2 relays for the 2 pink/lellow Acc wires on the truck?
Posted By: kreg357
Date Posted: January 07, 2011 at 6:51 AM
Here is the 2005 Ram 1500 info from AudioVox:
Battery RED (+) IGNITION SWITCH HARNESS Ignition 1 PINK/WHITE (+) IGNITION SWITCH HARNESS Ignition 2 PINK/GREEN (+) IGNITION SWITCH HARNESS Accessory 1 BLUE (+) IGNITION SWITCH HARNESS Accessory 2 PINK / YELLOW (+) IGNITION SWITCH HARNESS See Note Starter 1 YELLOW (+) IGNITION SWITCH HARNESS Note: THIS WIRE WILL TURN ON THE ABS LIGHT IF NOT POWERED UP FOR REMOTE START. THERE ARE TWO OF THESE WIRES, USE THE WIRE THAT DOES NOT SHOW 12VOLTS WHEN THE KEY IS IN THE ACCESSORY POSITION.
For a successful remote start install, you will need to locate, check and verify all the ignition wires with a DMM, as these are only guides. The Viper has a Flex Relay output that can handle one extra ignition wire. It comes defaulted to IGN2 and can be changed thru option programming to ACC2 or Starter2. Leave it at IGN2 and use it for the trucks Pink/Green IGN2 wire. The ACC2 wire will be powered by an extra relay and inline 20A fuse using the Vipers (-) 200mA Accessory Output as follows:
Relay Pin 86 and Pin 87 to +12v constant thru 20A fuse. Relay Pin 30 to vehicle ACC2 wire @ ignition switch. Relay Pin 87A not used - insulate. Relay Pin 85 to remote start (-) 200mA Accessory Output.
Assuming the Audiovox info in correct, the H3 heavy gauge harness would go like this:
Viper Truck Ignition switch H3/1 PINK (+) IGNITION 1 INPUT/OUTPUT to Pink/White H3/2 RED / WHITE (30A) FUSED IGNITION 2 / FLEX RELAY INPUT 87 to Red H3/3 ORANGE ACCESSORY OUTPUT to Blue H3/4 VIOLET (+) STARTER OUTPUT (CAR SIDE OF THE STARTER KILL WIRE) to Yellow - cut truck side H3/5 GREEN (+) STARTER INPUT (KEY SIDE OF THE STARTER KILL WIRE) to Yellow - cut switch side H3/6 RED (+) FUSED (30A) IGNITION 1 INPUT to Red H3/7 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT to Pink/Green H3/8 PINK/BLACK FLEX RELAY INPUT 87A key side of FLEX RELAY Not Used H3/9 RED / BLACK FUSED (30A) ACCESSORY/STARTER INPUT to Red H3/10 N/C N/C
The Red +12v constant wire at the ignition switch must be capable of suppling to current needs of the Viper. ------------- Soldering is fun!
Date Posted: January 07, 2011 at 7:19 AM
Thanks kreg357, that's exactly what I was looking for and how I have it wired up right now on the "kitchen table". Just wanted to make sure before I started installing tomorrow on the truck.
Thanks for all the help everyone!!
Date Posted: January 08, 2011 at 6:07 AM
Ok, after searching and reading more about the accessory wires on this truck, can someone who has installed a RS in one of these trucks tell me exactly how many acc wires I need to hook up? I have H3/3 orange going to the blue in the truck, and a relay from the RSO connector, orange (-) acc output, to the pink / YELLOW that is NOT powered with the key in the acc position. Do any of the other pink / YELLOW need power also? I am reading different answers with the different diagrams I have.
Thanks all.
Date Posted: January 08, 2011 at 9:35 AM
Ok, after searching and reading more about the accessory wires on this truck, 2005 dodge ram 1500, can someone who has installed a RS in one of these trucks tell me exactly how many acc wires I need to hook up? I have H3/3 orange going to the blue in the truck, and a relay from the RSO connector, orange (-) acc output, to the pink / YELLOW that is NOT powered with the key in the acc position. Do any of the other pink / YELLOW need power also? I am reading different answers with the different diagrams I have.
Thanks all.
Posted By: zerepdivad
Date Posted: January 08, 2011 at 12:39 PM
best practice is to replicate exactly what the key does.
------------- A DMM is a beautiful thing.
