directfax document 1094
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125659
Printed Date: June 15, 2024 at 11:55 AM
Topic: directfax document 1094
Posted By: omng464
Subject: directfax document 1094
Date Posted: January 13, 2011 at 9:27 PM
Working on an 05 ford excurson and installing a viper 5101. The ford has keyless entry already and I cant seam to find the document 1094!! Can someone email it to me? Thanks
Posted By: Twelvoltz
Date Posted: January 14, 2011 at 7:48 AM
It's easier to just pulse the ignition with unlock to wake up the GEM. Even if you were to use 1094 you would have to set the unit to double pulse unlock...so just pulse the ignition at the same time and it wakes up the GEM.
------------- Installer, IT support, and FFL. I need less hobbies.
Posted By: omng464
Date Posted: January 14, 2011 at 8:09 PM
Is all I need to do is run a jumper wire to ing 1 and will work?
Date Posted: January 14, 2011 at 8:24 PM
A relay activated by the unlock output from your system to the ignition wire in the truck will do it. Just remember to set the unit to double pulse unlock...first pulse will wake up the gem, second will unlock.
85 negative unlock output from system
86 and 30 constant fused +12V
87 Out to ignition
Posted By: texastommy
Date Posted: January 14, 2011 at 8:43 PM
Great tip Twelvoltz! Thanks!
Date Posted: January 14, 2011 at 10:15 PM
I just re-read the thread and realized that I should point out that you still need to hook the unlock output to the vehicle as well.
The unlock wire will activate the relay mentioned above AND the unlock in the vehicle...first pulse will activate the ignition, waking up the GEM (and pulse the unlock with no effect), second pulse will activate ignition AND unlock the door.
