audi a6 1996 remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125664
Printed Date: May 15, 2024 at 7:43 PM
Topic: audi a6 1996 remote start
Posted By: ultimo007
Subject: audi a6 1996 remote start
Date Posted: January 14, 2011 at 1:50 PM
hi i have installed a remote start system in my audi but think there is interference from the alarm/immobiliser it has the resistor palet in the key and acording to the wiring data base my car has got a disarm wire negative. the problem i have is that i can some times start the car with the remote and then the next time it wont. is there a way i can put a resistor in place to sort the passkey and how do i disarm the factory alarm as there was no wire of the new alarm module to conect to it.
Posted By: pimpincavy
Date Posted: January 14, 2011 at 2:52 PM
A 96 Audi should not have a security chip in the key. As far as disarming the alarm you need to hook up your unlock wire from the remote start to the unlock wire in the car. Its a BROWN / green wire in the drivers kickpanel. You will need to set the starter to double unlock pulse.
Date Posted: January 14, 2011 at 5:58 PM
hi need the resistor relay diagram the key has one of those resistors in cause when i leave the key in the ignition the remote start works. so just need to imatate that
