2001 jeep grand cherokee, avital 4103
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125692
Printed Date: May 10, 2024 at 2:31 PM
Topic: 2001 jeep grand cherokee, avital 4103
Posted By: co_ne_dub
Subject: 2001 jeep grand cherokee, avital 4103
Date Posted: January 16, 2011 at 9:54 AM
Hi,
I am trying to find which wire to connect the toggle switch (neutral safety switch) to. Cant find that info anywhere and I would like to avoid taking out the center console if possible.
Thanks and you guys have a great online community here!
Posted By: smokeman1
Date Posted: January 16, 2011 at 10:16 AM
Are you talking about the H2/1 BLACK/ White wire? And is the vehicle an Automatic?
------------- When all else fails, Read the Instructions
Date Posted: January 16, 2011 at 3:04 PM
Yes on both counts.
Date Posted: January 16, 2011 at 3:56 PM
Just run that wire to a good ground. No need for the toggle switch.
Posted By: Twelvoltz
Date Posted: January 16, 2011 at 9:11 PM
I like to use the included toggle switch through the BLACK/ white to ground as a way to shut off the remote start. In addition to the hood pin it gives an additional layer of protection. When you are going to have the vehicle serviced just flip the switch to off and the remote start is disabled.
------------- Installer, IT support, and FFL. I need less hobbies.
Date Posted: January 17, 2011 at 5:37 PM
OK new problem or maybe I just missed something.
Keyless entry does not work!
I was under the impression that the iDatalink would handle thhat kind of thing without the need for relays. Was I misinformed?
Been going through wiring and double checking, and I am at a loss.
Any ideas?
Date Posted: January 18, 2011 at 2:51 PM
Got it figured out.
RS232 and D2D are not compatible, I did not know that.
So after I went wire to wire everything works great!
Thanks for the help!
Date Posted: January 21, 2011 at 6:55 PM
Just so you are aware, theoretically the RS232 and D2D should be compatible. There is something up with the 4113/4103/4111 Avital units and their D2D...a different system might have worked fine with the D2D connection.
