diode, door triggers, 02 jeep tj, 5701
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125698
Printed Date: June 11, 2024 at 2:00 PM
Topic: diode, door triggers, 02 jeep tj, 5701
Posted By: bob351c
Subject: diode, door triggers, 02 jeep tj, 5701
Date Posted: January 16, 2011 at 1:55 PM
Im installing a viper 5701 in an 02 jeep tj. everything is hooked up and works great except the door triggers. they are - trigger and diode isolated. The striped side (cathode?) is facing the vehicle wiring for both triggers. But the alarm always shows a door open, i tested both diodes and the drivers side tested good but the passenger one was open (no current) in both directions. i cut out the offending diode and installed a new one, same thing open both ways, i unsolder this new diode and tested it works fine! i twisted yet another diode in and again open both ways but disconnect the door trigger and it works fine. Do i just need a bigger diode or what's the deal? I was under the impression once a diode goes its dead not that it would work outside the circuit. any help would be great
Posted By: godd dan it
Date Posted: January 16, 2011 at 11:46 PM
Should look like that. -------------
Posted By: bob351c
Date Posted: January 16, 2011 at 11:54 PM
ya its all hooked up right. diode tests good out of circuit and bad in it
Posted By: howie ll
Date Posted: January 17, 2011 at 3:10 AM
Did you originally test the door trigger before the diode, I've been installing for 20 years plus, I buy approx. 200 at a time and I've NEVER had a failed diode.
