2008 ford f250 sjb keypad, door ajar prob
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125774
Printed Date: May 31, 2024 at 9:09 PM
Topic: 2008 ford f250 sjb keypad, door ajar prob
Posted By: rv4jesus
Subject: 2008 ford f250 sjb keypad, door ajar prob
Date Posted: January 21, 2011 at 9:46 AM
I have a 2008 Ford f250 with a 6.4L diesel. I wanted to find the factory keypad code so I took off the SJB. Now the all the door ajar errors are showing on the dash and the power door locks don't work using the switch on the door but they do work with the keyring remote and the lights on the door keypad are off. I screwed something up and hope the SJB is OK. Any suggestions?
Thanks in advance.
------------- thanks for your help everyone
Posted By: rv4jesus
Date Posted: January 21, 2011 at 10:14 AM
Would you believe WD40 on the connectors came to the rescue! Door lock from door switch is working with no door ajar errors. Praise the Lord!
Does anyone know which connector was at fault? There were 6 that I reseated, all except the power cable.
Now I just have to check that the keypad is operating and try to set the factory keypad code. I thought it unfair to pay the dealer $60 to retrieve it but this was sure a stress inducer.
Thanks in advance.
