2010 audi s4 remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125976
Printed Date: May 28, 2024 at 7:28 PM
Topic: 2010 audi s4 remote start
Posted By: stang351w
Subject: 2010 audi s4 remote start
Date Posted: February 01, 2011 at 10:00 PM
Hello, i've been givin the wonderful task of finishing a remote starter that was partially installed into a 2010 audi S4 with a manual trans. The shop installed the remote starter but said there was no bypass for the clutch. the bypass that was used is a Idatalink one (not sure excatly which one but i do have a ADS-AL-CA which will work for the car) im just wondering if someone has done a remote start on this style car and able to help me out with bypassing the clutch. thanks
------------- Tri County KustomZ
certified installer
Posted By: tedmond
Date Posted: February 02, 2011 at 10:18 AM
have you tested at the clutch to see how it works?
shoot howie II a pm, he might be able to help you out.
------------- Ted
Compustar Expert
Date Posted: February 02, 2011 at 10:38 AM
at this time i haven't looked uner the dash. I contacted my tech line and asked them about it and they had told me that there was no clutch wire and that it was to be controlled by the bypass module and they had no other information on it. So i called ADS and they told me the ADS-AL-CA would work. but ith two different storys and no information i figured befor i start digging into this sweet car...i'm going to do some homework lol
certified installer
Posted By: howie ll
Date Posted: February 03, 2011 at 6:37 AM
Get out your DMM and start looking for the clutch switch, even if it's data a relay would still by-pass the switch.
Date Posted: February 03, 2011 at 1:50 PM
alright..thanks for the info. would it also matter if it has the key port for the ignition rather then the normal key?
certified installer
Posted By: howie ll
Date Posted: February 04, 2011 at 6:16 AM
RUN!!!
Date Posted: February 04, 2011 at 8:19 PM
hrmm...not sure if that's good to hear or not lol.
certified installer
