compustar 2w acting up
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126279
Printed Date: May 21, 2024 at 5:44 AM
Topic: compustar 2w acting up
Posted By: saleen49
Subject: compustar 2w acting up
Date Posted: February 23, 2011 at 6:36 PM
My Compustar 2W8000FMR(3000) has worked great for many years. Last year the 2 way remote quit so I use the basic 1 way remote now to start the vehicle. The battery on my Ford Ranger went bad so I replaced it with a new one. Ever since the battery issue occurred, my Compustar settings have all changed. It seems to be in diesel start mode. The dome light comes on now when I lock the doors. Doors lock automatically in passive mode now. I played around with bottons on the remote including reprogramming it to the 3000cm. Now the truck won't sense the tach and keeps shutting down. Is their a way to reset to factory settings on my 3000cm head?
Posted By: pitoaudiovisual
Date Posted: February 25, 2011 at 10:04 AM
what i have noticed is when ever i had a customer and they jump start the car due to a battery dead i have always had to replace the unit cause the internal components fry or short out. U might have to replace the Brain.
------------- Confidence is the key to any project!!
Date Posted: February 25, 2011 at 10:05 AM
It will lock and unlock and lights flash but it will not start
Posted By: saleen49
Date Posted: February 25, 2011 at 10:17 AM
Ok..The truck was never jumped. The problem began during a period when the original truck battery was failing. It was zero degrees outside. I remote started it but the battery was too low to fire the motor while in RS mode. It cranked real slowly and quit before it fired. It did fire and start with the key just fine. The unit was still remote startable up until Tuesday when I was trying to disable diesel mode. Now it won't stay running. All my settings are now changed since the low truck battery incident. My 2 way remote is broken and I have been working with the white 1 way remote. I really don't have it in my budget to buy a new system right now because I am in school. Was hoping to get buy with this unit until i was employeed again.
Thanks for the reply
Posted By: prdjr165
Date Posted: February 25, 2011 at 10:42 PM
I can second the jump starting issue:it happened to my brother on his 05 escalade,one jump start and the compustar was fried.
Posted By: tedmond
Date Posted: February 27, 2011 at 9:38 PM
never had a compustar unit die from jumpstarting.
reset the brain and program it all from scratch.
check if you are in valet mode.
------------- Ted
Compustar Expert
Posted By: saleen49
Date Posted: December 28, 2011 at 10:23 PM
I was able to reset the brain and all is fine again. I had to borrow an OP500 to return some of the settings to default though. What a pain in the rear this was. All because the car battery was weak.
Posted By: tedmond
Date Posted: December 29, 2011 at 12:02 AM
you dont need an op500 to return settings to factory. that can be done with the remote/brake pedal.
------------- Ted
Compustar Expert
Posted By: phil6710
Date Posted: January 01, 2012 at 9:27 PM
I came acrossed a copustar unit a CS-600s that hada simaler problem. Some how almost all the programable options were changed to option 2 or 3. I reset itand it was fine. ------------- Solartech Window Tinting and Electronics,contract installer
Posted By: offroadzj
Date Posted: January 01, 2012 at 9:42 PM
I just started getting into Compustars, but I believe that they have an extra safety feature where they will go into Valet mode whenever the battery is disconnected or goes dead. Apparently this is an added safety in addition to the hood switch. May be something to keep in mind...
------------- Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
