1996 bmw m3
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126719
Printed Date: May 04, 2024 at 7:58 PM
Topic: 1996 bmw m3
Posted By: pv13
Subject: 1996 bmw m3
Date Posted: March 25, 2011 at 3:55 PM
Can someone please help me find the wire colors and locations for a 1996 BMW M3. I have looked everywhere, and even asked some of the installers in my area about the car, and no one can find it for me.
My cousin bought this car with everything already installed. He had it in storage for the winter, and during that time he lost the alarm key chain control, and now the car doesn't start because the alarm is still activated with the remote start. The previous installer never put in a valet switch, and so now my cousin wants me to remove the alarm all together. But I want the wiring diagram, so I can be extra safe. I would appreciate any help you guys could give me. Thanks
Posted By: chev104275
Date Posted: March 25, 2011 at 4:48 PM
#65253: 1996 BMW M3 2DR SEDAN WITH 3.2L ENGINE AND STANDARD AUDIO SYSTEM
Security
WIRE COLOR POLARITY LOCATION
Battery RED / GREEN (+) OR RED / BLU IGNITION HARNESS
Ignition 1 GREEN (+) IGN HARNESS GRN ALARM PLUG
Starter 1 BLACK/ BLUE (+) IGN HARNESS GRN/BLK ALARM PLUG
All Door Trigger RED / BLUE (+) MODULE BEHIND GLOVE BOX (THIS WIRE DIMS)
Trunk Trigger WHITE/ BROWN (-) DRIVERS KICK
Hood Trigger VIOLET/GREEN (-) MODULE BEHIND GLOVE BOX
Alarm Disarm BLUE/RED (-) NEED TO PULSE AFTER START FOR REMOTE STR
Alarm Arm W/LOCKS
Parking Lights REMOVE SWITCH (+) 4TH WIRE FROM LEFT ON RIBBON CABLE (NOTE
FOURTH WIRE FROM LEFT LOOKING AT SWITCH IN RIBBON CABLE
Convenience
Headlights-Lo YELLOW (+) HEADLIGHT SWITCH
Wipers-Lo BLACK/ GRAY (-) OR BLK/BLU STEERING COLUMN
Trnk Release GRAY/RED (-) AT SWITCH IN DASH
Remote Start
Ignition 2 VIOLET (+) OR VIO/WHT IGNITION HARNESS
Accessory 1 VIOLET (+) IGN HARNESS OR VIO/WHT ALARM PLUG
Anti-Theft Type RF ACTIVATED SYS.
Anti-Theft Descript EWS II
Tachometer BLACK (-) DIA. PLUG PASS SIDE OF ENG ROUND BLK PLU
Speed Sense BROWN / RED (AC) IN HARNESS FROM GAUGES
MAY ALSO BE BLACK/ WHITE
Brake Lights BROWN / WHITE (+) SWITCH ABOVE BRAKE PEDAL
Reverse Lights BLUE / YELLOW (+) AT GEAR SELECTOR SWITCH
Horn BROWN / RED (-) STEERING COLUMN
Modules
WIRE LOCATION
Module 1 LOACTED BEHIND GLOVE , WHITE BOX
Doorlocks/Windows
Power Unlock BLUE/RED (-) PIN 22 THIS WILL DISARM ALARM DOUBLE PUL
REQUIRES DOUBLE PULSE
PowerLock WHITE/ BLACK (-) PIN 20 OF MODULE BEHIND GLOVE BOX:WHT BO
LF Window Up LF:BLACK/ WHITE
RF Window Up RF:BLUE/GREEN LR:BLACK / YELLOW RR:WHITE/ YELLOW
LR Window Up LF:VIOLET/WHITE
RR Window Up RF:YELLOW /GREEN LR:BLUE/GRAY RR:BLUE/RED
------------- If i Can't Install it I Don't need it Joe
Posted By: pv13
Date Posted: March 26, 2011 at 1:04 PM
Thank you so much.
