starter interrupt
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=127195
Printed Date: May 14, 2024 at 2:22 PM
Topic: starter interrupt
Posted By: TINTNMOREOK
Subject: starter interrupt
Date Posted: May 02, 2011 at 2:20 PM
What would be the best way to install a starter interrupt on a 2010 Lincoln Town Car. The customer wants to deactivate the starter interrupt by pulling up on the turn signal stalk.
------------- Tint 'N More
Posted By: Mark Mizenko
Date Posted: May 02, 2011 at 2:30 PM
Use a DEI model # 102T
perfect for what you need
Date Posted: May 02, 2011 at 3:14 PM
Thanks, where would I find the signal from the turn signal stalk? ------------- Tint 'N More
Date Posted: May 06, 2011 at 1:19 PM
The connector at the switch??
What are you looking for, hi-beams, or turn signal. I'm not sure what you mean by, "pull up on the handle"
Posted By: howie ll
Date Posted: May 06, 2011 at 1:22 PM
Yes, my thoughts as well Mark. Please clarify Tint and we'll try and help.
Posted By: howie ll
Date Posted: May 06, 2011 at 1:24 PM
This does seem a long way round, surely the factory immobiliser does the job, using the indicator stalk is going to give electronic grief.
Date Posted: May 09, 2011 at 9:28 AM
This customer had this feature installed on a previous Town Car by the dealership. No one at the dealership remembers where they got the component that they used to make this happen. Bottom line - the customer is familiar with this feature and would like the same thing installed on his new Town Car. So, I was thinking I could cut the starter wire, install a simple starter interrupt (like the diagrams on this web site suggest) and trigger it using whatever signal I get when I lift the turn signal lever.
One of my concerns is whether the immobiliser would be an issue. I think it would not but I'm not certain.
Any thoughts?
jim
Posted By: howie ll
Date Posted: May 09, 2011 at 9:40 AM
Yes but totally unnecessary. ------------- Amateurs assume, don't test and have problems; pros test first. I am not a free install service.
