Hi.
I'm looking for the wiring diagram for my new 2011 Hyundai Elantra, so I can install a remote starter. I haven't decided which remote starter yet, but I will need a bypass also.
Thanks.
Seems to be two flavors for the 2011 Elantra. Push To Start and regular key. Bulldog Security has the Elantra
W/O Smart Key listed. Here is a link : https://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
For the bypass, try Fortin. Here is a link to their site for more info : https://ifar.ca/en/vehicles/hyundai/elantra/2011/
With the EVO-ALL ( PTS ) or EVO-CAN ( Regular key ) you get a coupon to use their wire list for the vehicle
wiring for free. They list 23 wires and 19 pictures for the 2011 Elantra Regular Key model.
Thanks Kreg327 for your fast reply. The car is a 4 door sedan, regular key. I would like to use a bypass that did not need another key such as key in box.
Thanks.
The Fortin EVO-CAN is a No Key Required bypass module for that application. Comes pre-loaded with the firmware and with the included coupon gives you free access to the Fortin Wire List w/pictures. Just make sure the module you purchase is Hardware Version 3. Here is a link to the install guide : https://ifar.ca/en/download/3296/preview.html See install Type 8. It also includes some color pictures of the wire connection points.
Here is a link to the remote start units that are Fortin Data-Link compatible with the EVO-CAN bypass for an even easier installation : https://ifar.ca/en/datalink/
