compustar
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=127466
Printed Date: May 20, 2024 at 8:52 PM
Topic: compustar
Posted By: thecoolmankyle7
Subject: compustar
Date Posted: April 26, 2011 at 12:17 AM
I have a question about compustar remotes. I have a FT-6000AS-CONT brain and the RF-2W900 remote. As I understand the brain I have is the pro brain and I have the less than pro remotes. My question is if i buy a pro 2 way remote will it program up to my brain and antenna since I already have the 2 way antenna?
Posted By: syl20rochon
Date Posted: April 26, 2011 at 7:11 PM
Have you checked on Compustar's website? The band of your remote is FM and the PRO remote is SST. For sure, the brain can take it, the worst scenario is that you will need to change the antenna as well. You should send an email to Firstech before ordering.
------------- Sylvain Rochon
MECP security specialist
Tech support for remote starters
26 Years of experience counts
I'm here to help.
Date Posted: May 26, 2011 at 8:18 PM
I have a compustar with the 6000 brain on my f250 I'm not new to installing but I am new to compustar. I follow the programming table to a tee but in never seams to be in programming at all. Can some one please give me a step by step when lighs are suppost to flash and so forth. If you can tell me the order I can look at the table for which buttons to press.
Before any one suggest it I can't take it to a dealer the closest one is 3 hours one way and he doesn't have the op500 programmer either. You can't get info in compustars website unless your a dealer and they won't help talk to me at tech support either since I didn't buy it from a dealer ( not one close by)
Posted By: phil6710
Date Posted: May 26, 2011 at 9:28 PM
what option are you tring to program and why. That starter should be ready to go if you hook up the tach wire and program the tach. I havent programed a compustar with out an option programer in years. You can buy them on line at places like ebay.Usualy compustars tech support is among the best. Best thing to tell them is that you have a copustar installed in a vhical you just bought and tell them there is no dealer near by. I am sure they will help you out.
------------- Solartech Window Tinting and Electronics,contract installer
Date Posted: May 26, 2011 at 10:34 PM
I have bunches of things I need to program. I want it to lock with remote start cycle I need to turn the dome light on. I need to set it to diesel wait (its not waiting at all right now) I cant get compustar to help me in tech support because I'm not an authorized dealer. Compustar was nice enough to let me send in my brain and program several things like the POC outputs and a few things that you have to have the programmer for but when it comes to trouble shooting i'm on my own. The system is installed and all the current options work (remote start, locks, alarm..) but I cant program any of the options. I have a copy of the programming tables and can see all the options I need to program and the table that shows what buttons to press to change these options but the alarm seams to not respond. Im not sure if there are some missing steps or something I need to know. I am very familiar with installing DEI and Blackwiddow alarms and have installed several compustars but it has been at least 6 years since I installed a compustar and the shop I worked at then had the programmer...
Any Help would be great
Posted By: kreg357
Date Posted: May 27, 2011 at 7:07 AM
Do you have a Blade cartridge installed ( or one available ) and the ADS USB programming cable? There is a way to update / flash the CM6000 brain to the latest firmware revision and set all of the programming options ( except the Special Option groups ).
------------- Soldering is fun!
Date Posted: May 27, 2011 at 10:00 AM
I do have a ADS USB programming cable but no blade cartridge. Do you know how to go about doing that?
Posted By: kreg357
Date Posted: May 27, 2011 at 11:19 AM
Sure, but to do it you must temporarily insert a Blade cartridge into the CM6000.
After the Blade is inserted, connect the ADS USB cable to the CN6 connector port on the CM6000. Go to the iDatalink site at : https://www.idatalink.com/helpdesk/ and click on "Flash Your Module" in the upper right corner. (If you have never done this before on that PC, you might have to download some drivers. The process will step you thru it.) The next screen should show your Blade cartridge type and the firmware ( if any ) currently loaded. Select any firmware and go to the next screen. This screen will allow you to flash the Blade but more importantly will automatically update the CM6000 firmware ( if necessary ) and in the lower left allow you to configure all the options that are normally available via the remote FOB programming. Nice graphics and pull down menus. Just make sure you save any changes when exiting. You can do this on the bench or while the brain is still in the car. ------------- Soldering is fun!
Date Posted: May 27, 2011 at 2:17 PM
I've done many module flashes we use idata link and expresskits every day. You only problem is we havent started using the blade stuff yet so I don't have any blade modules. Will it flash at all with out it? I'm going to try it as soon as I get a free min.
Posted By: kreg357
Date Posted: May 27, 2011 at 4:56 PM
No, the iDatalink Flash program must see a Blade module to get past the first screen. I have seen some used Blade TB's without the harness on EBay real cheap, less than $10...
Date Posted: May 27, 2011 at 10:49 PM
I guess ill have to try to find one because I trieded it before I read your post and you are correct, it sees the brain there but wont do anything....
Date Posted: May 28, 2011 at 12:42 PM
Can you use a compustar pro Antenna with a non pro remote?
Posted By: kreg357
Date Posted: May 28, 2011 at 1:01 PM
There are many different varieties out there. One way, two way, AM, FM, 4 Pin, 6 Pin, U.S. & Canadian. Look on the back of the antenna for some type of ID, like ANT--1W900SH, AM 1W-433, ANT-1WSH or ANT-1W900FM. That will give you a clue as to what will work.
Date Posted: May 28, 2011 at 3:42 PM
Ok will do. If you have a sst pro 2 way antenna will it only work with pro 2 way remotes or could you use the other 2 way remotes? I guess I'm asking are the nicer antennas compatible with lesser quality remotes?
Date Posted: June 01, 2011 at 6:25 PM
Incase anyone elese comes across this form and needs to know how to do the programming with the remote its pretty simple. You have to have the 2 way remote.
Hold the 2 buttons down that are first on the programming table. and the alarm will chirp
Hold the 2 buttons down that are second on the programming table. and the alarm will chirp
Press button 4 the corresponding number of time for the option you want ( the alarm will only chirp once each time you press the button)
Once you stop pressing button 4 wait for the alarm to start chirping. It will chirp the same number time for the option you selected
Now press the button for the change you would like to make from the option table.
The end done.
Every option must start at the very beginning of the programming instructions and you can do one after the other, you dont have to wait for it to exit programming,
Posted By: franknitty69
Date Posted: June 01, 2011 at 10:34 PM
the pro 2 way antenna (SS) is not compatible with all remotes. it is compatible with the 2-way and 1-way ss remotes (RF-P2W901-SS, RF-1WG5-SS, etc).
The 900 mhz remotes are compatible with the older antenna. ------------- "When the slugs penetrate you'll feel a burning sensation..." - Prodigy of Mobb Deep
Date Posted: June 01, 2011 at 11:24 PM
Awesome thank you I have been trying to figure out what would work with what. I need to find a pro antenna now.
Posted By: planethax
Date Posted: August 19, 2011 at 11:10 AM
Can you do this with the RF-P2W901-SS remotes?
I try this and it just turns shock sensor on or off?
