ford transit 2006 mk 7 dead lock wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=127826
Printed Date: May 23, 2024 at 1:27 AM
Topic: ford transit 2006 mk 7 dead lock wire
Posted By: hksplumbing
Subject: ford transit 2006 mk 7 dead lock wire
Date Posted: July 05, 2011 at 2:11 PM
Hi All
I have finished my alarm install in my 2006 mk7 transit swb 110 T280 except the dead locking.
I have been trying to locate the deadlock wire?
Can anyone please help me. I have had information to enable me to fit the alarm. This is the only thing
i need to finish off.
Thanking you for your help
Anand
Posted By: howie ll
Date Posted: July 05, 2011 at 5:29 PM
Find the motor wire that shows 12V+ (yellow or yellow/black?) when you deadlock with the factory remote (lock button twice?) then take aux 3 (I'm assuming this is a 650), set it to work with alarm activation and program it timed for 4 seconds then look at this diagram, you will need a standard 5 terminal relay and a 1N4004 diode:- 3F2_relay_1.bmp------------- Amateurs assume, don't test and have problems; pros test first. I am not a free install service.
Posted By: howie ll
Date Posted: July 05, 2011 at 5:37 PM
Sorry just realised you have a 300, it's aux B grey/violet read the instructions, you can program it manually to do as I stated in the last post. N.B. The original Clifford instructions had the aux A grey/blue and aux B grey/violet mixed up.
You can incidentally use the other aux and set it up the same way to find the side/rear door unlock using the relay set-up as above giving you priority unlock. In that case leave it as a pulse setting, only 0.8 seconds required.
Posted By: the viking
Date Posted: July 27, 2011 at 5:04 PM
Hi there Howie I see that you are a UK installer and I to have the same van as above that I have fitted a viper 1000 alarm to which is working as a stand alone item and is not connected to the factory door locks but would like to be able to arm the alarm which will also lock all the factory doors. I see you mention in you posts above to locate a wire where is this to be found? and how would I go about connecting it up to my Viper 1000
Posted By: howie ll
Date Posted: July 27, 2011 at 5:30 PM
Use an aux or a second lock output if there is one, sorry much too late to take you through it blow by blow, much of the vehicle wiring explanation is above.
Date Posted: July 27, 2011 at 5:42 PM
Hi there Howie thanks for the quick reply but as I dont come here to often maybe I cant see something that is linked to the vehicle wiring all I can see is a SPDT diagram ? But that dont tell me where to look for the factory connetion I need to locate
Posted By: howie ll
Date Posted: July 27, 2011 at 5:49 PM
If your vehicle has an uncovered bin on top, it's where the passenger feet go, you can see the box behind the glove box and the loom goes towards you.
If you have a lidded top and the fuse box is behind the glove box, then remove glove box lid and pull forward to you to remove the front of the fusebox revealing the wiring.
