fiesta rs turbo wireing diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=127911
Printed Date: May 28, 2024 at 1:49 PM
Topic: fiesta rs turbo wireing diagram
Posted By: jwgrst
Subject: fiesta rs turbo wireing diagram
Date Posted: July 14, 2011 at 9:16 AM
hi im new hear i need a wireing diagram for a fiesta rs turbo 1991 so i can fit clifford avantguard 5.5 thanks
Posted By: howie ll
Date Posted: July 14, 2011 at 4:56 PM
There's nothing you need to know about that car that you can't sort out with a DMM.
You will probably need to change the door switches they've probably failed by now.
Tach at coil, ignition black, starter BLACK/ blue, ACC yellow, indicators, probably BLACK/ green and BLACK/ white all above except tach are in steering column looms. Sorry just worked on a 2012 Fiesta, it's somewhat different.
Posted By: jwgrst
Date Posted: July 15, 2011 at 11:44 AM
ok thanks for the help do u have thi info for the wireing for avantguard 5.5
Posted By: howie ll
Date Posted: July 15, 2011 at 12:18 PM
It's protected to the trade, I can install but legally can't give you any instructions. They don't want the public installing. It's a professional job and as such won't honour any warrantee unless installed by someone like myself.
