2012 kia sorento
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=128693
Printed Date: May 15, 2024 at 1:31 PM
Topic: 2012 kia sorento
Posted By: maxcat
Subject: 2012 kia sorento
Date Posted: October 01, 2011 at 12:17 PM
Hi guys, just trying to verify some wire locations in this vehicle.
 I am looking for the can 1 high and low and the can 2 high and low locations as well as the data wire location in this vehicle.
The paperwork I have is for a 2011 and wanted to make sure it is the same as a 2012. I show the data wire in the passenger kick panel,blue/orange or blue, and the can 1 low and high at the obdll connector. I also show the can 2 wires red and blue at the back of the fuse panel.
 Any help verifying the location and colors would be greatly appreciated, as they are required connections for the evo-all bypass module.
Thank you in advance
Posted By: chev104275
Date Posted: October 02, 2011 at 4:49 PM
I just did one yesterday the 2012 is the same as the 2011. Ive done quite a few if the new sorentos using the idata link ads al ca bypass. And they have worked great. Im assuming its a push button start. I know all the wires for the idatalink bypass are under the drivers side. The 2 can wires are in the back of the fuse box i believe high is blue and low is red if i remember right. The fuse box drops right down 3 10mm to remove the box
Also the idata bypass gives you tach that so far has worked for me
