resistor passlock bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=128761
Printed Date: March 09, 2026 at 12:24 PM
Topic: resistor passlock bypass
Posted By: surovich
Subject: resistor passlock bypass
Date Posted: October 08, 2011 at 1:41 PM
Im hoping someone can confirm something for me - I did a reading on my car and the OHMs during start were 4.5k, I had a 4.7k resistor around so I used that to bypass the passlock.  This is all working great, car starts with the remote and the key - but my yellow security light stays on at all times - should I worry about this?
Saturn Vue 2007 by the way.....
Scott
Posted By: surovich
Date Posted: October 08, 2011 at 2:12 PM
Sorry, I did more searching and some people say just use a 2.2k resistor instead?  If my value was off, I shouldnt start with the remote start, right?
Posted By: kreg357
Date Posted: October 08, 2011 at 7:44 PM
The resistor value is different from car to car.
Did you use the steps in this guide to determine the value?  https://documents.audiovox.com/700054.pdf
Did your relay setup and wiring look like the diagram?
