2006 tsx remote starter/keyless
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129774
Printed Date: May 23, 2024 at 3:04 AM
Topic: 2006 tsx remote starter/keyless
Posted By: vtech010
Subject: 2006 tsx remote starter/keyless
Date Posted: December 20, 2011 at 3:27 PM
hello i got a used recently and it has the viper 5109 everything works, fine. i would like to have the ignition lock feature work. it only lock after the key is had been turned on but does not unlock once the key is turned off. i downloaded the install guide for, i followed the instructions on how to set it, but still does not work. i entered, menu-1, feature-5 option-2. that's what it shows for the system. any help will be appreciated. it seems like ti goes to the default option to just lock and not unlock. perhaps it is not saving the option?
thanks
------------- What do i do now?
Posted By: Ohmz
Date Posted: December 20, 2011 at 8:42 PM
Try pressing the lock button engaging option 1. It's the reverse but I noticed this works on certain DEI keyless/remote start systems.
