05 300/c parklights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129775
Printed Date: May 14, 2024 at 8:53 AM
Topic: 05 300/c parklights
Posted By: kgerry
Subject: 05 300/c parklights
Date Posted: December 20, 2011 at 3:35 PM
does anyone know for sure the mux value for parklights in this thing?? Wire Magic says 2.4K, Astrochart says 1K and Directtechs says 1.67K...??
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: TROC4434
Date Posted: December 20, 2011 at 4:30 PM
Parking Light Negative Wire (-): WHITE/ Brown (To turn on the parking lights on this vehicle will require a (-) negative though a 1670 ohm and may also require a relay to connect.)
Parking Light Negative Wire Location: At Headlight Switch
Parking Light Positive Wire (+): WHITE/ Purple
Parking Light Positive Wire Location: In Passengers Kick Panel
Posted By: kgerry
Date Posted: December 20, 2011 at 5:05 PM
yes... i am capable of cutting and pasting as well... i was wondering if you have VERIFIED this?? as i get 3 different values from 3 different sources....
Owner/Installer
Classic Car Audio
since 1979
Posted By: TROC4434
Date Posted: December 20, 2011 at 5:15 PM
No I cant verify this because all the 300c Ive done I used bypasses.
Posted By: lectricguy
Date Posted: December 20, 2011 at 7:47 PM
Kevin-
If this helps, Code Systems, Audiovox, and Bulldog all have 1.67K as the Parking light wire value. Although I can't verify it, Code supplies OEM remote start systems for Chrysler, including the LX (300), so they have some credibility. ------------- Lectric Guy
Posted By: buddholly
Date Posted: December 20, 2011 at 7:48 PM
I can tell you that your multimeter will tell you the correct answer, and that if you use WHITE/ purple in the passenger kick you don't need a resistor.
